Old 12-11-2013, 05:35 PM   #1
brake short
Could this be the problem causing my brakes to pulsate?
newbrew77 is offline   Reply With Quote
Old 12-26-2013, 10:55 AM   #2
Incheon, S. Korea
BigBaron's Avatar
Probably not. Does it pulsate at slow speeds? Your boost may be set too high if it does.
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 12-26-2013, 10:58 AM   #3
The only time it pulsated was on the freeway doing 65 mph coming down a big hill. Other than that one hub gets hot. Trying to diagnose the problem
Old 12-26-2013, 11:07 AM   #4
Ford Idaho's Avatar
Is this a fifth wheel?
If so how level is it with the TV?
Old 12-26-2013, 11:08 AM   #5
No. Its a tow behind stealth toy hauler. Its level to the hitch
Sent from my SAMSUNG-SGH-I337 using Forest River Forums mobile app
Old 12-26-2013, 05:53 PM   #6
Incheon, S. Korea
BigBaron's Avatar
If only one hub gets hot, the first thing is check the adjustment of the brake pads. Second is to check the ground wires. I just fixed a weak ground on my trailer which is a very common problem as the ground connections corrode, just like on the top of a battery. Third, fix the wire in the picture. That will eliminate any concerns. I always solder trailer wire connections. If it still pulsates, pull the hubs. There might be a mechanical problem. If that's easy for you to do, I'd do it first.
Old 12-26-2013, 06:36 PM   #7
Yeah. I have checked the brake adjustment. Next is to start checking wiring. Are you saying to check the ground at the frame for corrosion?
Old 12-26-2013, 09:56 PM   #8
Incheon, S. Korea
BigBaron's Avatar
You first need to check the connection between the TV and the trailer. You can have a weak ground where it shows no resistance at low amperage, but high resistance at higher amperage. Also check the ground connections from each side to the wiring harness/frame. I was surprised yesterday by how much my connector had corroded. I had to replace the screw! Also those quick connects can weaken over time and cause a similar condition, which is why I solder and shrink wrap ALL wiring on my trailers. You can also coat the terminals with dielectric grease to help prevent corrosion.
Sent from my SHV-E110S using Forest River Forums mobile app
