Old 09-20-2014, 08:22 PM   #1
Medic911
Brakes???
I just got my Ram 3500 to tow my 5th wheel and I am trying to figure out the. Setting for the electric brake controller in the truck. It gives 4 choices of braking system? Thank you
Deejim is offline   Reply With Quote
Old 09-20-2014, 08:59 PM   #2
HONDAMAN174's Avatar
Can you list the choices please?
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 09-20-2014, 09:39 PM   #3
BBBlue's Avatar
From Pg 552 of the 2013 Owners Manual
Light electric- Electric trailer brakes under 10K load
Heavy electric- Electric trailer brakes above 10k load
Light EOH- Electric over hydraulic trailer brakes under 10k load
Heavy EOH- Electric over hydraulic trailer brakes above 10k load
Send me a pm, if you need an electronic copy of the manual.
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
2017 Days camping-190
2018 Days camping-66
BBBlue is offline   Reply With Quote
Old 09-20-2014, 09:42 PM   #4
You are going to be looking at the electric choices. Most people use the under 10k setting unless you are pulling a large 5r. Check your loaded weights and choose accordingly
Old 09-21-2014, 05:55 AM   #5
Medic911
Thank you all that replied. BBBLUE Master Chief, when did you retire? I am retired DECK LDO 2001.
Old 09-21-2014, 06:28 AM   #6
BBBlue's Avatar
Retired Jan 1996. Last command was COMPHIBGRU Two Det Norfolk, VA. Work Environmental, Health, and Safety for 12 years afterward. Fully retired at 59 and loving it!
What year is your Ram Truck?
BTCM(SW) Ret USN
2013 Sanibel 3500
Old 09-28-2014, 09:01 AM   #7
Use the heavy electric setting....the light electric setting in my 2012 3500 says it's only good for 3500 pounds or less
Tm_rich is offline   Reply With Quote
brakes
