Old 09-16-2012, 07:59 PM   #1
Brakes activate in R
Ok I have a dumb question here. When go to back into a camp site or just backup period the brakes activate on my 5er. Can anyone give me any advice on why this may be happening???
2004 Sierra 330RL 5th Wheel
2002 Silverado 2500 Duramax 4x4
States I have camped in
lonewolf is offline   Reply With Quote
Old 09-16-2012, 08:07 PM   #2
I would suggest checking the 7-way socket, sounds like there is a short between the "back-up light" lug and the TT brake lug. If you have a second 7-way socket on the bumper try connecting to it and see if the brakes activate in reverse.
Sirsea is offline   Reply With Quote
Old 09-17-2012, 07:52 AM   #3
lindy's Avatar
Could you have the brake controller set to high so that the brakes come on at the slightest touch of the brake pedal? Most people I know when backing ride the brakes slightly. If the controller is set too high/sensitive this might be causing it when you ride the brakes slightly.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 09-17-2012, 08:00 AM   #4
DDC
DDC's Avatar
Sounds like a broken spring on at least one brake, this causes the trailing shoe to pick up the drum while moving backwards.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 09-17-2012, 08:04 AM   #5
TURBS's Avatar
UN hook 7 way then try backing to eliminate the plug issue.
I always back my controller to 0 when I arrive at cg anyway.
If it still does it you have a hardware issue on one of the brakes.
Turbs
Old 09-17-2012, 09:17 AM   #6
Herk7769's Avatar
My money is here too.
Ocam's Razor.
The trailer brakes should not engage the drums in reverse.
HAM CALLSIGN - KC3FFW
Old 09-17-2012, 10:08 AM   #7
Depends on the brake controller. I had a Prodigy and if you wanted the brakes to not work in reverse you would have to hold boost for 5 seconds to disable them.
Len & Cheri is offline   Reply With Quote
Old 09-17-2012, 10:25 AM   #8
Herk7769's Avatar
Oh, I am sure the magnet is powered in reverse; just from looking at the animated drawing and the way the lever engages the pads it appears it should not work.
In a car, the wheel cylinder applies pressure evenly on both shoes at the top so the shoes will "grab" in either rotational direction. It looks like the magnet applied brake lever only will apply force to both shoes when the rotation is forward.
Been wrong before though and will be again ...
Need a real trailer mechanic (not one who plays one on the internet like me) who works on these guys to jump in.
Old 09-17-2012, 10:37 AM   #9
I would go with f1100turbo's solution first, unplug the 7 pin connector and see if the brakes activate in reverse. OP said it activates the BRAKES, not just one, so from that statement, I would suspect the trailer plug or the tv socket has a wire wrong.
Old 09-17-2012, 10:41 AM   #10
Herk7769's Avatar
Good point. I just wonder how he knows if it is one brake or all four.
I can't tell if I have a bad brake even going forward unless they lock up (which they should not if the brake controller is set properly).
brakes
