I finally had time to dig into this problem. I took all of your advice into account along the way. I ended up finding that the blue/white trailer brake wires inside the junction box on the RV were cut and arcing against each other. See the attached picture. If you look closely, you can see the black arcing on the blue wire. The brakes work great again. Thanks for all of your help.
2017 Salem Hemisphere 300BH
2006 Silverado CCLB 2500HD / Duramax / Allison
- Heavy mods / 950 lb/ft torque / 320k miles
