Old 08-04-2015, 02:04 PM   #1
Night Stone's Avatar
Brakes on travel trailer
Just wanted to pass this information to all. On my previous truck I had a Tekonsha Voyageur installed, basic stuff, no issues or warnings about trailer.
With this current truck I have the Tekonsha p3, which has the diagnostic feature. I am so glad we did. Why, because it only detected 1 axle not the second and was showing overload no brakes. So I had my trailer at a dealer for service work and guess what they found. Only one axles electric brakes was actually hooked up. The other was not, apparently the manufacture didn't fully push the connections in all the way for it work. Here I am driving the trailer the past 3 yrs and not knowing I have only set of brakes working and not both. Thus careless workmanship putting my family and others on the road at risk. Yes I am upset but I am glad the dealer caught it before the next trip we are taking.
Just wanted others in the forum to know to be sure to check your electric brakes for connections and such. If you don't have the diagnostic features from the brake controller to find issues.
Dave
98 Chevy Silverado C3500 crewcab, 454 cu in & 2013 Salem Cruise-Lite 181BHXL
FRF and FROG member
Days camped in 2012 (3), 2013 (3), 2014 (6)
Days camped in 2015, 0 Days so far (0)
This Space for Rent
Night Stone is offline   Reply With Quote
Old 08-04-2015, 02:23 PM   #2
GreenImp's Avatar
Send a message via MSN to GreenImp
A few weeks ago while prepping for a trip to Glacier National Park, I pulled my hubs to check my bearings. I found the wires to one of my brake magnets had been cut by the hub (installer didn't clip the wire out of the way properly).
The good news is I now have ONE brand new brake!
The bad news is I have ONE new brake (and 3 with a couple years worth of wear).
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 08-09-2015, 08:00 AM   #3
Phat Phrogs Incognito...
DutchF's Avatar
Time and again you read about poor factory workmanship, dealer tech screw ups etc. Seems like checking things like this yourself could prevent it. GreenImp did. I do too. And like GreenImp, yesterday while performing our yearly inspection, I found a failed seal that leaked grease and prevent one of the brakes from working.
No problem. New brake assembly was $50 from local trailer (not RV) dealer. Also found 3 of the factory lug nuts had thread stretch (not stripped) and were difficult to remove (and I use a torque wrench to install and check before each trip). I was not able to find the exact match and the RV dealer says it would take a couple weeks to order them. HA! Stop by my local Discount Tire (I love these folks) and picked up 32 new, heat treated, plated (not those cheap tin caps), locking lugs with TWO key sockets for $25! Replace all the factory nuts with better ones and they all spin right on now, smoothly!
Getting new tires Monday. Ordered a set of Sailun S637, G rated, 14 ply, all steel carcass (not just the belt) tires from local truck service center. Our Westlake E rated, 10 ply, steel belted tires lasted about 11,000 miles. (NOTE - our wheels are stamped with a rating of 3,960 lbs @ 110 psi which = G rating).
Tina + Dutch and Bell, Bobo, Harley, Buddy (the dogs)
2011 F350 Lariat 4x4 DRW SuperCrew 6.7L (B&W setup w/Air Lift 5000 Ultimate)
2014 Columbus 365RL (Airflex and Voyager package)
Nights Camped 2014 - 154, 2015 - 32, 2016 - 4
DutchF is offline   Reply With Quote
Old 08-09-2015, 08:04 AM   #4
nomad297's Avatar
You can't buy a better aftermarket brake controller than the Prodigy P3. I loved mine.
Bruce
nomad297 is online now   Reply With Quote
brakes, trailer, travel, travel trailer
