Old 10-26-2013, 07:48 PM   #41
Herk7769's Avatar
eTrailer is posting the load rating at a given PSI.
I don't recall them doing that before. I stand corrected.
Dexstar Steel Spoke Trailer Wheel - 15" x 5" Rim - 5 on 4-1/2 - White Powder Coat Dexstar Tires and Wheels AM20422
http://www.etrailer.com/Tires-and-Wh...r/AM20532.html
HAM CALLSIGN - KC3FFW
Old 10-26-2013, 07:52 PM   #42
Originally Posted by herk7769 View Post
I don't recall...
Now that sounds like a politician.
Old 10-26-2013, 08:08 PM   #43
Herk7769's Avatar
Seemed better than "I remembered that differently."
Old 10-26-2013, 08:11 PM   #44
Just messin' with ya'.
Old 10-26-2013, 08:21 PM   #45
Herk7769's Avatar
Seems 2150 pounds equates to 65 PSI
Americana Aluminum HWT Series S5 Trailer Wheel - 15" x 6" Rim - 5 on 4-1/2 - Black Americana Tires and Wheels AM22647HWTB
Old 10-28-2013, 10:14 AM   #46
Commercial Member
2150# @ 65 psi is a tire relationship not a wheel relationship.
The wheel does not know what the air volume is of the tire.
Have to consult Load/Infl charts.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 10-28-2013, 10:39 AM   #47
??? Sounds like double talk.
Old 10-28-2013, 11:36 AM   #48
Commercial Member
The ref of pounds load and inflation pressure when discussing the max rating of a wheel.
I don't know how "2150# equates to 65 psi" should be interpreted unless in reference to an inflation of 65 psi as it relates to a tire load capacity.
Just wanted to point out that you need to know the volume of air (tire size) to equate inflation pressure with load capacity.
Wheels have specific inflation limits which usually relate to the rim flange strength. The load capacity is usually limited by the disk portion of a wheel (where bolt holes are). Since these are two different portions of a wheel they are not tired to each other.
Hope this clears up the confusion.
Old 10-28-2013, 12:15 PM   #49
The reference Herk cited is from the wheel specs. Specs:
•Rim dimensions: 15" diameter x 6" wide
•Bolt pattern: 5 on 4-1/2"
•Wheel bolt size: 1/2"-20
•Offset: 0
•Pilot diameter: 3.19"
•Load rating: 2,150 lbs at 65 psi
•Limited 1-year warranty
Has nothing to do with tire size or volume of the tire itself. It merely states that the wheel will take a load of 2150 with 65psi of air in some size tire. Clearly the limit on the wheel.
Old 10-28-2013, 12:45 PM   #50
camper1999's Avatar
I find this thread kind of funny. We are only talking about the difference of 10mph which will only save you an hour and a half on a 10 hour trip and will eat up more gas. When pulling my trailer I try to keep it at 65mph and when I feel adventurous I push it up to 68mph. Part of my enjoyment when traveling is traveling.
2011 GMC 2500HD Diesel
tire, tires
