Old 03-15-2016, 07:26 AM   #41
WolfWhistle's Avatar
FYI, when my 4400# dexters were upgraded to 5200#, the brake parts (all) moved over.. The parts it took (what FR sent to local dealer) was axles, springs and equalizer. I am only assuming the spindles took the same bearings since the drums moved over. The ride height if it changed at all, was only slightly higher.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 03-15-2016, 04:59 PM   #42
WW
Now that makes me wonder, as I have the Lippert manual open and it shows the 4400lb brakes as 10" with a 4 hole bolt pattern and the 5200lb brakes as 12" with a 5 hole pattern. Not to say that you 4 bolt pattern may not bolt up, but if you have 10 X 2.25 vice 12 x 2" brake shoes you may still have 4400lb brakes!!! Just saying.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 03-15-2016, 06:53 PM   #43
Too Tall's Avatar
Yes!... x10....
Get a grasp on this concept: if you buy a 10# sack and put 10# in it, it COULD break; after some use, and abuse the odds of that increase. It is insane to complain that the sack is under-engineered. Absolutely, insane. Repeat after me: INSANE.
The human tendency for the most part, is to want something for nothing; and particularly in America; the lowest price is the driver; quality be damned. The demand for cheap goods has driven manufacturing off shore and is hurting all of us.
The RV industry isn't being deceptive or dishonest, the numbers are right there on the rigs; in BRIGHT yellow! I think people go gaga at the fake granite and fake wood; most wouldn't know quality if it smacked them in the face, and if they find it they would shy away after seeing the price. But, they totally ignore the important things. It isn't the industry and its isn't the poor engineer that we should be beating on. We have met enemy and he is us.
WW
I wholeheartedly agree, RV makers know what sells RVs - glitz and flat screen TV's. I don't think the RV industry is deceptive or dishonest as you mentioned, it's a business with shareholders as priority. (FR owned by Warren Buffet). But there little doubt about quality, maybe except for an RV sales person. Labor costs are so high and the prices low, a lot of corners are cut, as well as the quality of the materials use. I get your point on NAFTA but these things are made by Americans. Design also has to take some of the blame. It's a very competitive business for sure. For me, at my point in my life, cost is not important but quality is. I feel sorry for folks who have to finance their RV for a period of time longer than it will actually last.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 03-15-2016, 07:17 PM   #44
Too Tall's Avatar
Brand New Trailer - Axles Too Light for GVWR
Originally Posted by Kenny kustom View Post
I have 2k extra, and that's if I load my trailer to the max!
How much more do you want??
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Kenny, Thanks, I understand your point. But do you have 2K extra based on the GVWR or axle load. I weighted my little RV the other day and my GVWR, leaves 80 lbs before I'm overloaded. I weigh 200 so I'll have to sleep in the truck, ha, ha.
USMC 68 -70
Old 03-15-2016, 09:46 PM   #45
AquaMan's Avatar
That only means you put too much stuff into your RV. If the stuff you take is required, you should have bought a bigger trailer. (I have seen 42' 5ers with low cargo for the size though, I had one, but was not overloaded). This is what I've been trying to say all along. People max out the weight of a trailer, then blame the engineers for designing it with not enough cargo weight. You wouldn't buy a 2500lb gvwr flat bed trailer to haul 3000lb. Same goes for a camper. Everyone needs to take a little bit of responsabilty here.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
Old 03-15-2016, 10:27 PM   #46
Too Tall's Avatar
Yes, I weighted it as heavy as I could get it other than some clothing and food supplies. (I'll have to watch my wife with the can goods.) I had full propane and I recently added 2 - 6 volt batteries which added an additional 120 lbs on the tongue. I weighted it with a full tank of water (30 gal) so to stay within the GVWR, I'll may have to leave some water out. My axles which are 2200 x 2 dexters had 1920 front and 1980 back so I'm not overloaded on the axles even with water. What was surprising, is my tongue weight was 860 lbs. Gross trailer weight was 4780. That seems heavy but I'm happy to put it on the rear of the RAM as it easily handles that even without the distribution bars. (just going to the scales). The water tank is about halfway between the tongue and the hitch.
USMC 68 -70
Old 03-15-2016, 11:42 PM   #47
Usually Confused Member
emm-dee's Avatar
I think most of the info here is pretty accurate, but I'll add another factor. I have a Forest River enclosed utility trailer with a sticker gross weight of 2980 pounds. The single axle is rated at 3,500 pounds and the tires are 1870 each (3,740 total).
I couldn't figure out why all the different numbers but when I asked an independent shop about it they told me that any trailer without brakes installed from the factory were always placarded at 2,980 or less. Since I was at the shop to purchase a set of brakes, they checked the trailer and said that with the brakes I was good for 3,500 pounds. I asked about the springs and got the same number, but they also said they would be glad to install a 5,200 pound axle/spring combo since the frame would easily handle that. Don't need that because the heaviest weight I carry is a small Kubota tractor tipping the scales at just under 1,500 pounds.
So, in this case the gross weight is limited by legalities of brake status.
2018 Forester 3051S (aka Clyde)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 03-16-2016, 09:00 AM   #48
In Florida trailers 3000# or more must have trailer brakes, as well as breakaway, and there is a 40% weight requirement.
There is more to weight ratings, than what the frame, springs, axles and tires can carry. Brakes, as was pointed out can be a limiting factor.
Florida statute XXIII chap 316...
(3) BRAKES ON ALL WHEELS.—Every vehicle shall be equipped with brakes acting on all wheels except:
(a) Trailers, semitrailers, or pole trailers of a gross weight not exceeding 3,000 pounds, provided that:
1. The total weight on and including the wheels of the trailer or trailers shall not exceed 40 percent of the gross weight of the towing vehicle when connected to the trailer or trailers; and .... (also)
(4) AUTOMATIC TRAILER BRAKE APPLICATION UPON BREAKAWAY.—Every trailer, semitrailer, and pole trailer with air or vacuum-actuated brakes, every trailer and semitrailer with a gross weight in excess of 3,000 pounds, and every pole trailer with a gross weight in excess of 3,000 pounds manufactured or assembled after January 1, 1972, shall be equipped with brakes acting on all wheels and of such character as to be applied automatically and promptly, and remain applied for at least 15 minutes, upon breakaway from the towing vehicle.
(5) TRACTOR BRAKES PROTECTED.—Every motor vehicle manufactured or assembled after January 1, 1972, and used to tow a trailer, semitrailer, or pole trailer equipped with brakes, shall be equipped with means for providing that in case of breakaway of the towed vehicle, the towing vehicle will be capable of being stopped by the use of its service brakes.
Hyper Lite was sold
Old 03-25-2016, 11:47 AM   #49
I think it could be said that they are precisely engineered. It's the end user that doesn't understand the engineering and ignores the numbers. If a trailer is engineered for 1000lbs or 10,000lbs of cargo, someone is going to say that "when I put 999/9,999lbs of cargo in I'm near overloaded". It's simple math.
100 percent agree. It is the end user that doesn't buy "enough" trailer. They load it up and then cry that it's FRs fault, buy a bigger trailer for your needs. Don't cry because you didn't research and don't understand the numbers
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 03-25-2016, 11:58 AM   #50
TURBS's Avatar
I agree
axle, light, trailer
