Old 03-01-2016, 06:21 AM   #11
pull it a few miles and everything will probably be ok. they need to reseat and adjust to the adjustments you made.
rr retired is offline   Reply With Quote
Old 03-01-2016, 06:31 AM   #12
KyDan's Avatar
X2 plus I adjust my brakes until I feel light drag and move on. I never pull the brakeaway cable when doing this. Did you tighten yours enough so
there was at least a little drag when turning the drum without voltage applied?
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 03-01-2016, 07:02 AM   #13
Mark S's Avatar
This is the advice I like best so far . I tightened until there was a little drag and then backed a click or two. Still hear scraping.
Mark and Joanne
2014 Fun Finder XT 276
2015 Ford F150 Lariat 3.5 Ecoboost 4X4 SCrew Max Tow
2011 Harley Road Glide Ultra
Mark S is offline   Reply With Quote
Old 03-01-2016, 07:11 AM   #14
MtnGuy's Avatar
I tighten the brakes just enough so that I can't move the drum. That centers the brake shoes. I then back off ~5 clicks, and if still rubbing significantly, will back off 1 more. A little rub is not bad. I double check by spinning the wheel hard, and I like it to spin for 1 1/2 to 2 turns before stopping.
Old 03-01-2016, 07:15 AM   #15
The Best Advice is in "Dexter Service manual" they had them in their Vendor Booth for Free at the Goshen Frog Rally! It is online at Dexter also! When you Adjust the shoes you change the "Contact Arc Area" you will have a Small contact point to the drum,this will all be explained in the Dexter manual! Youroo!!
youroo is online now   Reply With Quote
Old 03-01-2016, 08:37 AM   #16
Left Coast
I seen last night? (grammer police)
Sent from my XT1080 using Tapatalk
Old 03-01-2016, 09:24 AM   #17
Mr. Dan's Avatar
(grammar police) - spelling police -- Ha OCW!
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 03-01-2016, 12:34 PM   #18
Tough crowd!
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 03-01-2016, 01:35 PM   #19
So I just finished repacking all my wheel bearings and cleaning and adjusting the brakes. As I finished each wheel I pulled the break away switch and felt the brake engage and made sure I couldn't turn the drum before putting tire back on.
On the last wheel, I tried turning the tire and while there was resistance because the brakes engaged, I was able to turn the tire. I replaced and removed pin again and still could move tire. I readjusted the brakes and the same happened. The brake is engaging, just not locking the wheel.
Since I checked all the other wheels by turning only the drum, not the tire, I am not sure if they were the same, although i don't think so.
Is there something simple I may be missing here?
Were you hooked up to your TV when testing?
Bill & Lynne
2014 Flagstaff MicroLite 21FBRS
2013 Nissan Frontier SV CC 4x4
Equal-i-zer hitch
Old Bill is offline   Reply With Quote
Old 03-01-2016, 01:37 PM   #20
Left Coast
Probably not...that's why he's using the breakaway for testing
brakes
