Old 09-23-2015, 06:43 PM   #1
Break away plug
I accidentally pulled out the black pin that plugs into its power source. Can you tell me where it plugs back into?
kh3805 is offline   Reply With Quote
Old 09-23-2015, 06:45 PM   #2
davel1971's Avatar
got a picture of "it"
David & Lynn
Old 09-23-2015, 06:52 PM   #3
Ford Idaho's Avatar
Little black box like this.
Old 09-23-2015, 07:16 PM   #4
DaveSchwartz's Avatar
If its the box Ford Idaho has shown, just push the pin back in (hard). Its just a piece of plastic that separates two contacts that look like a clothespin inside. Do it sooner than later because you have full energy from the battery going to your brake magnets as long as its out.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 09-23-2015, 07:51 PM   #5
davel1971's Avatar
you started a second post with no pic? I'm going to guess this time. Is it the break away for the brakes? TT has a little box on frame tongue, 5th wheels it's on pin box. Hole in front of the box to put pin in. Snaps in pretty tight.
David & Lynn
Old 09-23-2015, 07:52 PM   #6
Break away plug
There is a black box on the side of the frame near the tongue you should be able to push the pin back in. Make sure you do not have the battery hooked with the pin disconnected like this it will damage your magnets if the full 12v is applied for a long time.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 09-23-2015, 07:56 PM   #7
wmtire's Avatar
Originally Posted by kh3805 View Post
Accidentally pulled out the break away black plug- contact...can you tell me where to plug it in?
It will look something similar to this. It should be mounted on the side of you tongue frame. Make sure you push the pin all the way back into the housing. Problem is, if you have not disconnected your battery, you have been energizing the wires/brakes since the pin was pulled. You at least need to go remove the negative terminal from your battery until you get it back in place. You can also melt the switch having it energized for a long time.
2011 Flagstaff 831 RLBSS
Never Apologize! Never Explain!
Sorry, thatís my motto.
Old 09-23-2015, 10:41 PM   #8
I am new at this 😀
Where is this .... Will I have to unhook from hitch to get to it.
Do I need to disconnect the battery ?
I had no idea its been pulled almost 3 weeks
Old 09-23-2015, 11:11 PM   #9
wmtire's Avatar
Look along the frame rail, usually the driver side.
Old 09-23-2015, 11:25 PM   #10
Its a 5th wheel
