Old 03-01-2014, 07:14 PM   #1
Ret E-9 Anchor-clanker
donanddona's Avatar
breakaway switch
I currently use a battery tender during winterizing the 5r. I once thought of pulling the pin on the breakaway lock to ensure the 5r was secured. The question is what damage would occur to the break system.
donanddona is offline   Reply With Quote
Old 03-01-2014, 07:19 PM   #2
iceblaze580's Avatar
The break away should only be used in an emergency I would use some type of locking chocks or a king pin lock to secure the 5er
iceblaze580 is offline   Reply With Quote
Old 03-01-2014, 07:21 PM   #3
Kaadk's Avatar
Don't know your system, but some (read: all I've heard of) of those breakaways operate under power. I.e. Pull pin, drain battery.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 03-01-2014, 07:50 PM   #4
bikendan's Avatar
you could also damage the electric brakes, along with draining the battery.
they aren't parking brakes!
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-01-2014, 08:04 PM   #5
Brother Les's Avatar
You will energize the brakes and after awhile I would suspect that something in there would fry..... don't fry your wiring at your brakes or your batt. chock the wheels.
Brother Les
Old 03-01-2014, 08:10 PM   #6
Carknocker Family
Ida Ratherbe Camping's Avatar
x 2
You will end up replacing your magnets and some wiring more than likely, plus a dead battery if you do this. Wheel chocks are the way to go.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 03-01-2014, 08:33 PM   #7
B47
Like others have said, you'll fry your brakes,drain your batteries,and maybe burn up wiring by doing this.
If someone wants your RV bad enough they can simply reset (replace) the breakaway switch - it's a common replaceable item.
