Old 10-07-2016, 05:48 PM   #1
Broken spring hanger
Son in law has a Nitro XLR toyhauler. On a short trip today, one of the spring hangers broke at the weld to the frame. Has anyone ever experienced this and what is the best repair process? Has anyone reinforced these welds?
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 10-07-2016, 06:13 PM   #2
Grind and reweld it. I had that happen on a goose neck single drop from twisting the axles on off grade driveways. I added fish plates (triangular gussets) to all the spring hangers, not just the one that let go.
Enjoying my solitude.....
SidecarFlip is offline   Reply With Quote
Old 10-07-2016, 06:15 PM   #3
Davidg, could you pls provide us with a little more info about this NITRO?? (i.e. Year, model and maybe even some photo's. A lot of forum members have NITRO XLR toyhauler and like to try and stay ahead of problems like this if at all possible.
TIA for your time.
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
hdmtnrider is offline   Reply With Quote
Old 10-07-2016, 08:21 PM   #4
Sidecar, thanks. Your description makes perfect sense. Once we get it back home, we will re-inforce every hanger weld using the methods you describe.
Hdmt, I'll be taking a look at it tomorrow, and we'll get it home Sunday evening. We have a welder coming in the morning to look at it, and fix whats broken. I know its a 2015 year model. I dont know the exact model number, but it does have a gross weight of just over 16k. More info later.
Old 10-07-2016, 08:36 PM   #5
I would make the gussets triangular shape with a flat top that extended to both sides of the hanger and go down the hanger to the bolt head.
Old 10-07-2016, 08:43 PM   #6
Exactly. I made mine from 1/8" flat stock, plasma cut but my goose neck suspension, I subject to way more weight than a toy hauler.. I overload it all the time, sometimes 20 grand on the deck in an off road (as in farm field) situation.
The fish plates ended all the issues.
Old 10-12-2016, 01:30 AM   #7
Murbella7's Avatar
Woldwood Heritage Glen Suspension Failure
My 'Palace' is just 6mths old, done 3 trips, 200km, 2000km & 7000km.
Sure some roads were a bit bumpy but at a point about 2/3rds of the way through the last trip, inspection showed that the springs had all started to flatten.
When you also couple this with an incident at about the 4000km mark, a tyre exploded, wrapping the rubber around the slide-out and lighting wiring under the van, ripping it to shreds. This necessitated the use of an air-powered grinder, supplied by a Good Samaritan passer-by with a construction vehicle, (we were in the outback of QLD Australia) to release the mess and allowed us to remove the wheel.
The original 15", 1100Kg rated tyres were barely enough to carry the 4.5 tonne load, with very little tolerance between the tyre max rating and the load. At the place where we decided to get repairs, (Rockhampton), we were advised to replace the tyres with light truck versions. This meant we had to upgrade from 15" to 16" rims. Thankfully the full set of 5 rims and tyres only cost us $1320. The repairs to the wiring cost another $1000. All this was needed if we were to continue our trip with some reasonable safety and comfort.
What I am getting at here is the shock at discovering how grossly underrated the factory wheels & suspension system was for a vehicle of such size and weight.
So, new rims & tyres and soon a new (and radical design) Timbren suspension system that uses a see-saw arrangement with rubber buffers, no springs at all. The system is rated to 9 tons, comes with a 5 year warranty and cost under $3k. One look and I was in.
Name:	Timbren Suspension.jpg
Murbella7 is offline   Reply With Quote
Old 10-12-2016, 04:27 AM   #8
Mor Ryde offers a kit called the X Factor to deal with this. It consists of a brace that bolts on and runs between the spring hangers. Lippert also shows how to reinforce them by running 2" square tubing across the bottom of the trailer between the spring hangers. Does about the same thing only it's welded instead of bolted in place. Not an uncommon problem.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 10-12-2016, 07:28 AM   #9
Thanks for this information. Do you know where I can find out more about it?
