Old 06-17-2018, 07:18 AM   #1
Arefbee's Avatar
Angry Broken stud
Morning all. Hope all are happy campers, happy Fathers Day if applicable
So, I took the PrimeTime for fresh tires. The OEMs looked pretty old and cracked.
All went well, except they managed to break one stud off half way up.
I still have 19 more and could put a lug on the remnant and be fine for years... but I'd rather do it right.
Question for anyone who has ever had this happen. Should I replace just the stud or the wheel hub? $5 plus (my)labor for stud or $40 for the hub.
This is an 8yo trailer, had the hubs off 3 years ago, never had to remove a stud before. My tech level is knowledgeable amateur. I don't have specialized tools but know a good machine shop and I have 10 different sized hammers How hard will it (probably) be to remove the stud from the hub?
(I did a search for old threads but could not find any; could be b/c iPad browser is less than stellar)
2011 PrimeTime Tracer 2600rls
Arefbee is offline   Reply With Quote
Old 06-17-2018, 07:26 AM   #2
DDC
DDC's Avatar
Just replace the stud, itís an easy job just time consuming. You donít need any special tools, just get a bunch of flat washers with a larger hole diameter than the stud and use them to pull the stud all the way in.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 06-17-2018, 07:30 AM   #3
It's been a few years since I've had to replace a stud, but I did do it with basic tools...BFH...and a little sweat. At $40 for hub, I'd call it a toss up. Spend the time removing the broken one or just get a hub and be done.
TheWolfPaq82 is offline   Reply With Quote
Old 06-17-2018, 07:34 AM   #4
If your lucky you may be able to drive the broken stud out with out removing the hub. Good luck which ever way you get it done.
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
hdmtnrider is offline   Reply With Quote
Old 06-17-2018, 07:43 AM   #5
Gold Tee Box
Teetime's Avatar
Curious, how did they break the stud, over torquing maybe?
Success is hiring someone to mow your lawn so you can play golf for exercise.
2018 GMC 2500 Duramax Denali
2018 Coachman Freedom Express 287BHDS
42 campgrounds/292 nights since 2015
Teetime is offline   Reply With Quote
Old 06-17-2018, 07:44 AM   #6
I agree itís a toss up I have replaced several studs one or two practically fell out others tested my sanity. Honestly I might lean towards a new hub just because my luck isnít always good and in back of my mind I am thinking about changing tires on roadside and another stud breaks odds would be extremely slim but it would be there
moose074 is offline   Reply With Quote
Old 06-17-2018, 09:47 PM   #7
Arefbee's Avatar
I’d love to know how they managed to do it. I had the lugs off to check the brakes last, hand started each one so no cross threading. checked the torque a couple of times after, never had a battle.
Since there is so much stud left I’d say it didn’t bind until halfway up the shaft. The rest came off easily. I think someone was rushing and tried to plow through too much rust. They could have tapped it instead of breaking it but weren’t equipped to.
Well I’m going to try the stud before I order the hub.
Thanks for the feedback.
Old 06-17-2018, 10:41 PM   #8
A machine shop will charge you $10 to remove/replace a stud if the old one is rusted in there.
2017 Coachmen 233RBS
2018 Ford F150 Lariat
"Common sense is not very common"
babock is offline   Reply With Quote
Old 06-17-2018, 11:47 PM   #9
Iíve heard that half the diameter of a bolt is enough length to hold a nut, but I would change it.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 06-18-2018, 06:05 AM   #10
Who Dares, Wins
doc73's Avatar
Just asking but if a shop broke your stud off.. Shouldn't they be finding someone to repair? Not saying I'd let them fix it.. But they should be getting a repair person to make it right. Either way it's not hard to swap one. Used to do it on the trails all the time on my jeep and lifted ranger.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
