I tried it
I have a 21ss Roo, and in order to get load range D, I went to an 81 mph rated taskmaster tire from etrailer that was a 215/75-14 instead 205/75-14. It was about an inch taller tire, and I was a little worried about clearance. No problems after a long trip to Yellowstone and several shorter trips. I highly recommend going to a higher speed rating and load range. It gives you some insurance against blowouts. I often drive in AZ in August in 100 degree temperatures, and had lots of blowouts over the years. I changed to Taskmasters on all 3 of my trailers, and no problem so far. For some reason, E-trailer doesn't list the speed rating for their tires in the specs. It was mentioned in the video.
