Old 05-18-2014, 08:00 AM   #1
Orion's Avatar
Can I use more tire pressure?
I want to go to 15" LR D tires.
The current tires are at 50 psi and the GY Marathons would be at 65 psi.
I have looked all over the wheels and can't find anything about a max PSI for the wheel. How can I know if I am good?
2017 Flagstaff FLT21DS
2011 Tundra Platinum, 5.7l, 2WD, Firestone bags...
Orion is offline   Reply With Quote
Old 05-18-2014, 08:04 AM   #2
davel1971's Avatar
any brand info on wheel you can research?
David & Lynn
Old 05-18-2014, 08:16 AM   #3
Oklahoma Proud
MillerTime's Avatar
I think OC has those tires on his trailer which I thought was a Rockwood or flagstaff. He is always saying to put load range D on , so It is working fine for him.
And sometimes wheels have specs on the backside of the spokes
Ps. The 50 -65psi jump isn't quite like a 44psi-80 jump, im sure it will be fine.
MillerTime- Future Sabre Handler!!
Old 05-18-2014, 08:21 AM   #4
Orion's Avatar
I have tried with no success.
Forest Rivers components list and manufacturers did not uncover anything either.
I took one wheel off to get any information off I could find. Nothing really useful, at least through Google yet. The trailer came with LR C Trail Express tires.
This is what I do know. Stamped on wheels -
Max 2150 LBS
SR WHEELS
SR0048 (or 4B?)
15X6 J L
DOT-T
Made in CHINA (Arg!)
Old 05-18-2014, 08:53 AM   #5
Batts-toy's Avatar
My old rims didn't show air pressure either but did show max load which was so close to my TT weight I replaced them along with the tires and went to the Maxxis 'E' tires.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 05-18-2014, 09:11 AM   #6
Airdale's Avatar
Max 2150 LBS
SR WHEELS
SR0048 (or 4B?)
15X6 J L
DOT-T
That is a 50 psi rim.
Airdale
Airdale is offline   Reply With Quote
Old 05-18-2014, 09:53 AM   #7
Mark S's Avatar
So what happens if you exceed the rim PSI? If a rim is rated at say 65 psi and you go to 80 psi. Will the rim explode or have a catastrophic failure? Is the aluminum rim weaker that a rubber tire?
I replaced "C" rated 50 psi tires on a rim I am told was 65 psi rated with Maxxis "E" rated 80 psi tires. Can 15 or 20 psi really damage or cause a failure ?
Mark and Joanne
2014 Fun Finder XT 276
2015 Ford F150 Lariat 3.5 Ecoboost 4X4 SCrew Max Tow
2011 Harley Road Glide Ultra
Mark S is offline   Reply With Quote
Old 05-18-2014, 10:21 AM   #8
f5moab's Avatar
Airdale
Is that based on the actual rim or the load rating?
f5moab is offline   Reply With Quote
Old 05-18-2014, 01:17 PM   #9
Airdale's Avatar
The load rating.
Retailers - such as Tredit - that provide tires and rims to the RV trailer manufactures often fit their tire & rim assemblies very close in load capacity. Plus sized replacement tires more often than not will also require rim upgrading. Here is a reference to ponder.
Modular
Airdale
Old 05-18-2014, 03:05 PM   #10
f5moab's Avatar
I understand that when equipping tires and rims it is usually to rate them close together.
However, you cannot use the load rating of a rim to determine its max pressure.
Load rating has nothing to do with the max pressure of a rim as it does with a tire.
For example, the HI-Spec rims I have on my trailer have a load rating of 2150 lbs, but a max pressure rating of 80 psi. And that pressure rating was stamped on the back of the rim.
15x6 Series06 Aluminum Hi Spec Trailer Wheel 5 Lug, 2150 lb Max Load Free Shipping.
A steel rim I purchased at the same time for a spare, has a load rating of 2600 lbs but a max pressure of 60 psi.
15x6 White Spoke Trailer Wheel 5 Lug, 2600 lb Max Load
And the Dexstar steel rims that came on my trailer from the dealer, had a load rating of 2040 lbs and a max pressure of 65.
pressure, tire
