Old 04-22-2016, 05:47 AM   #11
Who Dares, Wins
doc73's Avatar
While you COULD spin the axle 180, it is not recommended due to the preload in the axle.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 04-22-2016, 10:47 AM   #12
Originally Posted by Mars View Post
Correct, OP was asking about turning them over.
Yes, but looks like I have to go with the regular flip. Bummer is that I don't have a flat area to put the trailer on and do it myself.
proride is offline   Reply With Quote
Old 04-22-2016, 01:41 PM   #13
Nope. Axles are pre-bent to accommodate the load. Bend looks like downturned lips. Rotate 180 degrees to upturned lips and your wheels will be splayed out at the bottom=bad.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 04-22-2016, 01:56 PM   #14
Just hook it to the tow vehicle and jack it up on the frame. Doesn't have to be on level ground as long as you can get both tires on the same axle off the ground.
Old 04-22-2016, 03:26 PM   #15
Originally Posted by doc73 View Post
Why? If the axle is just moved under the springs, nothing is rotated. Nothing to rotate. The hardest part is jacking the trailer.. I know I did it the swap.
Sent from my SAMSUNG-SM-G870A using Tapatalk
I'm kind of with Mars on this. When you rotate the axle tube isn't it going to rotate your backing plates etc at the same time? Or what am I missing.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2013 22 nights.2014 57 nights.2015 116 nights
2016. 96 nights 2017 72 nights.
Filterman is offline   Reply With Quote
Old 04-22-2016, 04:48 PM   #16
You are correct, if it's a 180 rotation like my original question, yes everything is rotated. But that is not going to work as I did not account for the axle being angled.
axle
