04-21-2016, 04:43 PM
Can you rotate an axle 180 degrees?
I have a Coachman 17FQ and need to get a little more clearance for 15" tires. So I know that the axle needs to be under the springs, and a new perch needs to be welded on the top of the axle as that is what everyone seems to do.
But I was laying under the trailer looking at the axle setup, and it seems like all that needs to be done is just rotate the axle so the spring perches are on top.
That just seems too simple, what am I missing?
04-21-2016, 04:53 PM
Who Dares, Wins
Typically axles are bent upwards to allow for the weight to "straighten" it. You need to weld the new perches. Now a lippert kit I had seen said they did not need to be welded but recommended a tac weld.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
04-21-2016, 05:01 PM
Ok, that makes sense. I knew I was missing something.
04-21-2016, 05:47 PM
There is no need to weld the saddle on either the Lippert or Dexter kits since the new saddles brace against the existing ones welded on at the factory. Just take careful measurements so the new saddles are parallel with the old and once you torque the u-bolts it ain't gonna move.
That said I did weld mine since I have a welder and it only took a second or two after I had everything "right" where I wanted it. The part that took me the longest time was jacking up and supporting the trailer.
John & Mary Jo
Enjoying the adventure
04-21-2016, 06:02 PM
Who Dares, Wins
Yeah, DO NOT use the stabilizer jacks to hold things up... That will end badly for you.
2015 Chevy HD D-Max
04-21-2016, 07:25 PM
You also need to rotate the brake assemblies.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
04-21-2016, 09:32 PM
Who Dares, Wins
Why? If the axle is just moved under the springs, nothing is rotated. Nothing to rotate. The hardest part is jacking the trailer.. I know I did it the swap.
2015 Chevy HD D-Max
04-21-2016, 11:05 PM
It's called an axle flip. Wheels stay in same position axle just gets moved above or below springs. I gained 3-4"s. Looked a little goofy with the smaller tires but it gave me the clearance it needed. Back skids were dragging on driveway apron prior to flip.
04-21-2016, 11:47 PM
Who Dares, Wins
Yes it does. Have 14" rims and the little 27" tires. I gained prob 5" of lift!
2015 Chevy HD D-Max
04-22-2016, 05:41 AM
Correct, OP was asking about turning them over.
04-22-2016, 05:47 AM
Who Dares, Wins
While you COULD spin the axle 180, it is not recommended due to the preload in the axle.
2015 Chevy HD D-Max
04-22-2016, 10:47 AM
Yes, but looks like I have to go with the regular flip. Bummer is that I don't have a flat area to put the trailer on and do it myself.
04-22-2016, 01:41 PM
Nope. Axles are pre-bent to accommodate the load. Bend looks like downturned lips. Rotate 180 degrees to upturned lips and your wheels will be splayed out at the bottom=bad.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
04-22-2016, 01:56 PM
Just hook it to the tow vehicle and jack it up on the frame. Doesn't have to be on level ground as long as you can get both tires on the same axle off the ground.
04-22-2016, 03:26 PM
I'm kind of with Mars on this. When you rotate the axle tube isn't it going to rotate your backing plates etc at the same time? Or what am I missing.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2014 57 nights.2015 116 nights .2016 96 nights .2017 72 nights. 2018 157 nights. 2019 52nights.2020/21 118 nights. 2022 115nights
04-22-2016, 04:48 PM
You are correct, if it's a 180 rotation like my original question, yes everything is rotated. But that is not going to work as I did not account for the axle being angled.
