Old 04-21-2015, 12:13 PM   #11
Left Coast
Originally Posted by gr8white View Post
That was a great video Fonzie and exactly what I was looking for. Thank you! I think on my last trip I high pinned the hitch unfortunately. I had to un hitch and hitch again. Then I drove 16 straight hours and was a nervous wreck because the lock was sticking sideways because it had tension on it. I hope I didnt damage my hitch.
If you mark the hitch handle, both open and closed, might give you a visual. Also, sometimes a flashlight looking at the jaw(s) will tell if closed.
Old 04-21-2015, 12:15 PM   #12
Left Coast
If you mark the hitch handle, both open and closed, might give you a visual. Also, sometimes a flashlight looking at the jaw(s) will tell if closed. Depends on what type of hitch your using as to solutions.
Old 04-21-2015, 07:36 PM   #13
robert.beck.7737's Avatar
Try Googleing "How to properly hook up a fifth wheel hitch." The person appearing in this video is a Reece Hitch retiree and appears to know what he is talking about.
robert.beck.7737 is offline   Reply With Quote
Old 04-21-2015, 07:40 PM   #14
I saw a great idea for making sure the jaws are locked around the king pin. Paint the jaws a bright yellow. Shine s flashlight on the underside of the hitch after you have connected with the king pin and you will readily be able to see if the jaws are closed around the king pin.
Old 04-21-2015, 07:46 PM   #15
Ret E-9 Anchor-clanker
donanddona's Avatar
Originally Posted by fonzie View Post
Thanks Fonze that's a great video !!! Wow...
donanddona is offline   Reply With Quote
Old 04-21-2015, 08:43 PM   #16
B and B's Avatar
I have the Reese Elite Hitch. I painted the jaw Red with paint and can visually see if it is locked as well there is a flag to see if it is locked then a put test. I do remove the X Chocks and use just rubber chocks for this. I also raise the landing gear a inch of so as to not bend them while doing the pull test. DW helps and reminds me of steps for hitch up.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-22-2015, 11:21 AM   #17
DaveSchwartz's Avatar
I have a Curt E16 hitch with a (possibly older) design that uses a sliding bar instead of jaws. I like it because once you put the handle down in the hitching position as soon as the kingpin pushes the release catch forward, the bar slides across behind the kingpin (very audibly!) and the handle moves in with it. If the handle has moved in so that there is no more exposed shaft, that bar is fully across - no question about it.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 04-24-2015, 11:16 AM   #18
Hi Dave, I believe I have the same hitch that you are referring to. Do I? So once it is locked I dont have to worry? Also, I was told that I should spray something on this with WD40. Is this true? If so, what do I spray?
gr8white is offline   Reply With Quote
Old 04-24-2015, 11:29 AM   #19
Left Coast
I used either wd or a light grease on the under side where the lock bar rubs. Do you use the Teflon disk on the pin?
Old 04-24-2015, 11:32 AM   #20
Yes I use a white disk on my pin. I dont think its teflon but just a hard plastic.
5th wheel, hitch, wheel
