Old 04-24-2015, 11:37 AM   #21
Left Coast
Originally Posted by gr8white View Post
Yes I use a white disk on my pin. I dont think its teflon but just a hard plastic.
Ya, it's just easier to call it Teflon.
Old 04-24-2015, 11:38 AM   #22
LOL I got ya. Where exactly should I spray the WD 40. I was thinking on the spring as well since its becoming rusty.
gr8white is offline   Reply With Quote
Old 04-24-2015, 11:41 AM   #23
DaveSchwartz's Avatar
Pictures attached of mine, opened and closed... not quite the same. The slide bar doesn't have the rod that the handle pulls visibly welded like yours but its the same concept.
I would use something a lot more heavy duty than WD-40 to lube it. I use Valvoline Cerulean (lithium complex NLGI-2 - basically a wheel bearing grease) and use a paint stir stick to dig it out of the tube and slather it on.
My 5er has the Reese Revolution pin so I don't use a disk (it doesn't pivot on the hitch). The grease on the head is just for sliding while hitching and unhitching.
Good to see that you use a lock - never move without it.
ID:	75104   Click image for larger version
Name:	Hitch closed.jpg
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 04-24-2015, 11:42 AM   #24
Left Coast
Surely couldn't hurt...... I lube whatever moves........the hitch that is!
Old 04-24-2015, 11:46 AM   #25
Left Coast
With our set-ups, using the disk, we don't have to lube the plate...they tell you not to.
5th wheel, hitch, wheel
