Old 02-19-2019, 07:08 PM   #1
Fluffywhitedogs's Avatar
Carlisle :(
I replaced my china bombs last summer with Carlisles. Researched like crazy and went with the best tires I could find out of the limited 13" choices.
Glanced at the trailer on my way to work this morning and saw this...
I went to a higher load range, but don't run heavy anyhow. Always check my pressure regularly. Don't go too fast.
In total, these probably have 5000km on them! 3000km just last month. Date code is 2117.
What?
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
Fluffywhitedogs is offline   Reply With Quote
Old 02-19-2019, 07:21 PM   #2
SeaDog's Avatar
That can happen with any tire good you found it before it blowout. I'm a real fan of Carlisles and run them on my car hauler with heavy loads with no problems (fingers crossed)
Retired Navy
2016 Flagstaff 26 FKWS
Old 02-19-2019, 07:37 PM   #3
This can happen with any brand. Glad you caught it!
2rad4u is offline   Reply With Quote
Old 02-19-2019, 07:44 PM   #4
Who Dares, Wins
doc73's Avatar
I'd still stick with the Carlisles. Probably a fluke, of possibly damage from a pothole / curb that any tire could get.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 02-19-2019, 07:56 PM   #5
When that tire is removed from the wheel, ask to inspect it. That can be caused by a damaged bead area allowing air to get inside the tire sidewall. Sometimes this happens during installation and doesn’t show up for a while.
2017 Silverado 1500
2018 Sonoma 280RKS
2001 Fleetwood Bounder 36U
onelung0210 is offline   Reply With Quote
Old 02-19-2019, 08:35 PM   #6
Now a "Top Member"
EdJunior's Avatar
And find out if there is a warranty (I'm sure there is one). I had Carlisle on my TT for 5 years and I don't know how many miles and trips. I only had one flat, and it was due to a nail. On my 5th wheel, I have Maxxis, but yeah, I don't know if they make them in 13".
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
Old 02-20-2019, 12:22 AM   #7
It should be covered under warranty. My confidence was just a bit shaken but you guys have made me feel a bit better. I’ll give Carlisle another shot!
Carmen and the pack
Old 02-20-2019, 01:22 AM   #8
Installed Carlisle trail hd tires 13" last spring. Towed 10,000 miles by fourth of July.
No problems at all.
Very happy with them.
MtBiker is offline   Reply With Quote
Old 02-21-2019, 10:54 PM   #9
I just noticed today that on my build sheet, the tire are listed as 175/80R13 and on my sticker, it says 185/80R13.
Does it matter?
Carmen and the pack
Old 02-22-2019, 12:24 AM   #10
The size matters in how it affects the load rating. A narrower tire MAY not have the same rating.
Although it may be very close.
Old 02-22-2019, 07:45 AM   #11
Carlisle 😞
Thanks! Apparently I read the sticker, not the sheet, when I picked the size, so they are 185’s on her now.
They are as heavy duty (with regards to load range and speed rating) as I could get in that size, so I will just call it a fluke, replace with the same, and move forward [emoji4]
Carmen and the pack
