07-11-2013, 09:37 PM
Changing a flat tire
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
07-11-2013, 09:50 PM
Always Learning
When I changed my tires, I tried using a ramp made out of lynx blocks- I went up 4" or 5" and it wasn't enough to get my other tire off of the ground due to my EquaFlex Suspension. I'd worry that the TrailerAide wouldn't get me off of the ground.
07-11-2013, 09:52 PM
Always Learning
There's also been a thread here in the last few months- you can do a search and they should come up.
07-12-2013, 07:00 AM
Sure does. I personally haven't used one, but we have one for our church trailer (heavier than my camper). A friend of mine recently had to change one of its tires and said it worked great. So now I have one in the camper as well.
2012 Surveyor SP280
2017 Ford F-250, 6.7L Powerstroke
Equal-i-zer
07-12-2013, 07:41 AM
I use 2 x 6 scrap lumber for leveling blocks.
I can put 2 pieces in front of a tire and pull up on it and the other tire
on that side will be off the ground.
No jack or special thingamagig to lift the wheel needed!
Peace!
Dan & Rita D
07-12-2013, 07:48 AM
I use the black one works great, use it to do the bearings too.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
07-12-2013, 10:40 AM
I borrowed one from a friend when I was swapping wheels and tires and it would not provide enough lift for me either, because of the equaflex. I tried setting it on a 2x4 and using a ramp of leggos could not get it to lift enough.
I ended up needing a jack to get mine off the ground, now there is a bottle jack that lives in the basement for occasions that call for lifting a tire off the ground.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
07-12-2013, 10:46 AM
They work great ONLY if the rim with the flat will come up off the ground when you drive the good wheel up on it. I have one and have to put a 2X8 under it to get the flat off the ground. Once on, it's very secure. I suggest to buy one locally and return it if it doesn't do the job.
10-15-2013, 04:06 PM
We had a tire with a very slow leak on our last trip and it had us wondering how we would change trailer tire (2304S) 14" tire. We carry a bottle jack where is the safe place to put it? Will Trailer Aid work on our size trailer & tires?
Pam
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
11-13-2013, 11:03 PM
I wouldn't be without a Trailer-aid for changing tires on a tandem axle trailer, repacking bearings, and adjusting brakes.
11-13-2013, 11:23 PM
Pam
Under the axle is where you want the jack. just be sure the jack will fit under the axle when a tire IS flat.
Nothing worse than a jack to tall.
01-27-2014, 03:05 PM
Just do not place the jack under the "axle" as the axle tube will not support the weight of a trailer. You will crimp the axle tube and then bad things happen. Jack on the frame, near the axle. Use something to spread the force point of the jack out a bit, like a 2x6 square of wood.
Brenda and John
Master Blaster of the Navy
01-27-2014, 03:37 PM
PPST OGCDG
If you use a Jack under the axle, do not put the jack where it touches the axle tube. Only place the jack where it is located on the axle U Bolt.
I now have a Trailer Aid and it works great.
I have used the stacking leveling blocks to change tires.
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
