Old 12-18-2014, 12:05 PM   #11
Where do we find the Marathon lrd tires. I have Westlake 205/75 14 load C on my 2015 Rockwood 2703WS from the factory. I have checked some local dealers and Tire Rack and no one has these Marathon D's I for a 14" rim. Also thinking of upgrading the tires on my 2013 F-150. Any recommendations and where to find them.
Rockwoodjoe is offline   Reply With Quote
Old 12-18-2014, 03:01 PM   #12
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
It doesn't look like Goodyear makes a Load D in a 14" rim. See the Goodyear link and click on Marathon to see their sizes. I checked Maxis too and they don't make a 14" Load range D either. Sorry
Goodyear RV Tires ‚€“ Tire Selector
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 12-18-2014, 03:45 PM   #13
Thank you Lloydg. Just not what I wanted to hear.
Old 12-18-2014, 04:24 PM   #14
jawga's Avatar
hankook makes a D range tire (couldnt find the kuhmos)for a 14" its a 195r14 euro specwhich is the same as a 205/75r14. we just swapped ours and it made a huge difference
jawga is offline   Reply With Quote
Old 12-18-2014, 05:05 PM   #15
Taranwanderer's Avatar
I hate to say it Joe, but if you upgrade to 15 inch rims you will have a much better selection of tires, load ranges, and brands--assuming you have the room to run a larger rim. I know, not the news you wanted to hear.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 12-18-2014, 05:36 PM   #16
HONDAMAN174's Avatar
Kumho does make a 195r14 in their 857 line. Ran it on my High Wall and loved it.
Also think about a tire pressure monitor. Different opinions on if they help on blowouts but I prefer to know if a tire is going down slowly.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 12-18-2014, 07:51 PM   #17
Angry Forrest river backing products
You give me hopes with forrest river co. I will call them again and see if they will, can help on my wolf pup, bought it brand new. It has negative camber where the tires, original, wear out in 1000 miles. It's the second set of tires too.
Safe man is offline   Reply With Quote
Old 12-18-2014, 09:56 PM   #18
I found D range tires on Etrailer.com. Size st205-75-14 for $106.95. Never heard of Kenda or Karrier brand. They must be Chinese. Maybe they come with eggroll.
Old 12-19-2014, 08:32 AM   #19
Road-King's Avatar
Originally Posted by Road-King View Post
When I had my Windjammer, I went from load "C" to "D" tires. I had the same question as the OP. I contacted LionsHead the supplier of my rims. They told me that my rims were rated for 50 psi, but if I went to a metal valve stem, I could go up to 80 psi. The rubber valve stems was the reason for the 50 psi limit. I had the fancy 15" aluminum rims.
From a old post
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 12-19-2014, 02:04 PM   #20
Airdale's Avatar
Probably the best upgrade for the ST205/75R14C tire is the ST215/75R14C tire. You wont have to change rims and you pick-up 110# of extra load capacity per tire. The 215 is about a half inch wider and taller than the 205.
Airdale
Airdale is offline   Reply With Quote
tire, tires
