06-06-2018, 06:10 PM
Cheap Handling Fix
I just got a 2019 coachmen mirada 35kb and starting to do chf. The problem I am having is the bolts on bushing end is stuck in bushing at both ends Have anyone else experiences this?
John and Diana Embrey Texas 2019 Coachmen Mirada 35 KB
06-06-2018, 06:13 PM
Now a "Top Member"
Well, I'm wracking my brain to come up with what "chf" is. It sounds like I won't be of any help anyway, but I'm sure not if I don't know what it is.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
What is chf? And what bushings you talking about, im confused.
Coachmen M/H
Concord
2018 / 300 DSC
06-06-2018, 06:16 PM
By the way congrats on the new 2019 Mirada, Coachmen are nice units, all of there lines. Seem to be very responsive to there buyers.
Coachmen M/H
Concord
2018 / 300 DSC
06-06-2018, 06:19 PM
Cheap handling fix the bolt I am talking about is in the bushing ends.
+3
The bushing is on the sway bar on a class a
06-06-2018, 06:21 PM
Bushing ends of what??
06-06-2018, 06:23 PM
cheap handling fix
06-06-2018, 06:29 PM
I just put 2 and 3 together and came up with 6 but I did figure out what you were talking about. Heat, and wedge bar and a big hammer comes to mind.
06-06-2018, 06:35 PM
That I always did old trucks but brand new I dia not expect to do that
06-06-2018, 07:36 PM
The CHF only calls for the sway bar links to be moved to the open position on the sway bar. Should be able to push up on the sway bars to align the link/sway bar holes. The coach should be on level surface to do the CHF and sometimes a car jack is used to raise the sway bar. I was able to do mine by hand.
06-06-2018, 09:09 PM
know this but, I can not get the bolt out of the link end on the bushing to be abe to bring the sway bar up put the bolt into 2nd hole. The bolt is frozen in the bushing and I need to rotate the bracket on the link bushing end.
06-07-2018, 06:35 AM
I would think something heavy held on the back side of the link and sharp hammer taps on the bolt will do the job. It shouldn't matter if the link sleeve also comes out as it can be forced back in with wd40 as a lubricant. Just a thought.
06-07-2018, 01:58 PM
Got it out soak it overnight with wd-40 and it pop loose. So now the rear is done the front next.
06-09-2018, 11:48 PM
Let us know what you think of the change after you've done the front.
06-10-2018, 08:33 AM
I had to use a bottle jack under the axle to tweak sort of speak to wiggle out and reinstall the bolt when I did mine. I wasn't perfectly level when I did this mod.
2016 Pursuit 33BH,
2012 Jeep Wrangler,
Sondors & Bolton E-Bikes
Blue OX
06-13-2018, 03:28 PM
Check to see if you get any interference with rear sway bar and the parking brake drum in front of the rear differential (surrounds the drive shaft). My 2016 Mirada 35KB had this setup and when parked on a spot where the rear was lower that the front there was contact between them when the rear was jacked up in order to level. I undid the CHF and instead went with the aux rear sway bar.
AL
2016 Coachmen Mirada 35KB
2016 Jeep Cherokee 75th Ann. Ed.
2007 Corvette Convertible
1997 F-350 CC PSD
