Old 09-02-2016, 04:33 AM   #1
Check valve stems
Our 2014 Salem 26TBUD had a tire with low air pressure. When filling it, the valve stem nearly broke off in my hand. Checked the other tires and all of the stems were cracked. This could have been a catastrophe if they failed on the highway. Had to take all to a tire shop for replacement. Check your valve stems in advance of your next trip.
tccommish is offline   Reply With Quote
Old 09-02-2016, 05:07 AM   #2
ilmor's Avatar
Good tip! Curious, are you in an area of high U/V such as AZ?
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 09-02-2016, 07:00 AM   #3
Better Tip,replace All with "Metal screw clamp type stems"! Youroo!!
Old 09-02-2016, 07:34 AM   #4
wmtire's Avatar
Also another tip along this line is to be careful of petroleum distillate tire/wheel cleaners you use, as they are bad about ruining the rubber valve stems.
2011 Flagstaff 831 RLBSS
Hypochondria is the only illness I don't have.
Old 09-02-2016, 07:55 AM   #5
Head Rambler
Good Advice right there. A lot of times we don't think about the little things that are affected by products we intend for something else.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 09-02-2016, 08:08 AM   #6
Looking Down Range
SkipnTerri's Avatar
X2!!
2014 Forester 3051S
2013 Ford Focus
SkipnTerri is offline   Reply With Quote
Old 09-03-2016, 08:41 AM   #7
Airdale's Avatar
When a person finds something that appears defective to them, the best place to start a search is in the NHTSA recall data base.
This is an older document I have in my document files but it's still got some good information about valve stems in it.
Recall of faulty tire valve stems expanded
USN - RET - PDRL
DOD - RET - Journeyman Aircraft Mechanic
SSA - RET
Airdale is online now   Reply With Quote
