04-07-2016, 07:50 AM
Constancy LY188 Speed Rating
My 2015 Puma TT has Constancy LY188 ST225/75-15 LRD tires on it. Nowhere on the tire does it state a max speed. No load rating followed by a speed rating, either, such as 113S. I looked them up online, and the manufacturer lists them as 113S. All retailers selling them show them as 113S, meaning S speed rating as well. That's a 112MPH speed rating I'm not buying that for a second. I've always been hesitant to even accelerate beyond 65 to pass a slow moving vehicle! Any thoughts?
04-07-2016, 08:13 AM
Not enough time in Recent Discussions to suit me, so….bump.
04-07-2016, 08:35 AM
Always Learning
From what I've read- if a ST tire doesn't specifically have a speed rating stamped on it, it is tested to 65mph.
04-07-2016, 08:44 AM
That would be my assumption, too. Still leaves me wondering why the manufacturer would clearly state on their website it is rated to 112mph, though???
04-07-2016, 08:57 AM
Always Learning
Is that the new ones? I think there was a recent change where new ST tires have to have a speed code stamped on them.
Have you thought about contacting them directly?
04-07-2016, 09:01 AM
My 2016 Coachmen Freedom Express 301BLDS came from the factory with Constancy LY188 ST225/75R15 tires installed. They do have both Load Rating and Speed Rating markings:
Speed Rating "L" (75MPH/120km/h MAX.)
Load Range D
Max Load Single 1150 kg (2540 lbs) at 450 kPa (65 psi)
Max Load Dual 1000 kg (2200 lbs) at 450 kPa (65 psi)
[/URL][/IMG]
[/URL][/IMG]
04-07-2016, 09:05 AM
As I under this the TRA sets the minimum requirements for the ST type tires in the USA. They very recently changed the speed requirement from 65 MPH to 75 MPH, with the additional stipulation that the speed rating had to be marked on the sidewall of the tire. So if your tire is not marked with the speed rating of L it is only rated for 65 MPH.
04-07-2016, 09:08 AM
I'm almost certain mine do not have that speed rating listed, but I'll check again later today. Mine were manufactured 4214. Still begs the question- why would the manufacturer list a completely different speed rating on their website than what is on the tire??? For some reason I just get the feeling that when a legit tire company wears out some equipment, they sell it to some of these guys who continue to use it to pump out subpar tires. But that's just me.
04-07-2016, 09:12 AM
That is likely true. Anyone want to make a bet that they didn't make any changes at all to the tires to increase the speed rating. My money is on the 75mph tires being identical to the 65mph tires.
04-07-2016, 10:14 AM
Always Learning
Websites are the ugly step-child of most companies and are generally poorly handled.
04-07-2016, 11:05 AM
TRA has set a new 81 MPH speed rating for ST tires manufactured after xxxx date without a speed letter. Older unmarked tires are still 65 MPH.
Tire manufacturers are not required to divulge manufacturing components of tires other than what is required by DOT to be on each tire's sidewall. They do have to certify to NHTSA that a speed rating is valid and testable.
A Trailer Tire Poster
04-07-2016, 12:37 PM
I'd say you are correct. I recently purchased Goodyear Marathons. Goodyear has a Public Service Bulletin that indicates you can increase the tire pressure 10 psi over the TT's sticker to increase the speed range to 66 - 75 mph.
04-07-2016, 06:20 PM
RetiredRVer
Since 2000, the NHTSA has required that all passenger car tires, as well as, all pneumatic mfg tires, have the load range, max cold tire inflation pressure, speed rating etc...stamped on the sidewall of all tires sold in the United States. I looked it up!
04-07-2016, 08:28 PM
Load range is not applicable to passenger tires.
The current description method for speed ratings has been used since 1971.
Speed letters have not and are still not mandatory for ST tires. The current adaption of service descriptions including speed letters for ST tires has been forced on those tires being imported. To pass customs without having to pay an increased tariff most ST tires must now have speed letters.
The official load capacity medium for ST and LT tires is the load range letters. They are also official for medium to heavy duty truck tires.
Passenger tires load capacity is presented on their sidewalls as a service description. Something like 100Q where the 100 will lead you to a chart depicting its load capacity and the "Q" is its speed restriction. Passenger tires also have a grading system called "Uniform Tire Quality Grade (UTQG) Standards".
The DOT allows the use of service descriptions on ST tires although they are not the official method used to determine their load capacity.
04-07-2016, 09:11 PM
RetiredRVer
What I said.....
04-07-2016, 09:33 PM
I just replaced a set of Constancy 188 tires that came new on my 2015 fiver. I sold the set for $200 on Craigslist to a guy who wanted them for his equipment trailer. I'll wager that he paid me more for them than FR paid for them as oem tires.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
04-08-2016, 07:53 AM
I've read tons of talk about FR (and pretty much all other RV manufacturers) using cheap "China Bombs" on new trailers. It sounds like the #1 recommended tire replacement is Goodyear Marathon Radials. What confuses me is that Goodyear Marathons are also made in China. What's the deal?
04-08-2016, 08:20 AM
(Dry Huunday)
Load Range D
Same here
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
04-08-2016, 08:47 AM
The Constancy 188's have a huge reputation for blowing out at hwy speeds. Never take them over 65. ST tires lose a third of their strength at 2 years of age whether they are in service or not. I wasn't waiting for a cheap ST tire to blow and take half the kitchen slide plumbing with it. Forum research led me to Maxxis tires which are not made in China. Mine were made in Thailand. Is that better? I dunno,....time will tell. I would have liked to install G614's, but ran into rim figment issues that became difficult to overcome. So, I'll be watching my new Maxxis tires closely to see how they hold up. I think it was Herk who suggested the Maxxis and use the savings to install a tpms system. After thinking about that for a day or two, I concluded it was a great suggestion, so that's what I did. Time will tell. Watch your tires closely no matter which brand. Blowouts can prove to be costly.
04-12-2016, 10:54 AM
I plan to go with Maxxis too. Onlinetires.com list them as Q rated but Maxxis.com just says it is a "high speed radial".
I am waiting to see if the rating is actually listed on the tire but haven't seen anyone comment on that yet.
2015 Rockwood 8289WS
2003 Dodge Cummins w/Banks 3:73
