03-28-2013, 10:12 AM
Cost to Service Bearings & Brakes
What would you consider a fair price to service the wheel bearings and brakes on our 2007 Flagstaff 831BHSS?
Thanks in advance for the help,
Rick
Rick (K8RWG), Joy, and Daffy (the spoiled Calico cat)
2014 Rockwood 8315BSS
2016 F250 SC LWB 4x4 6.2 3.73
Reese Dual Cam
Honda EU2000i
03-29-2013, 11:01 PM
Paid $240 Canadian at a dealer up here.....teach me for being too lazy to do it myself. Won't happen again!
Stu & Jackie Metcalfe
2000 Salem FKSS
2008 Sierra 2500 HD gasser
03-29-2013, 11:06 PM
240.00$ plus parts is a fair price. Youroo!!
03-29-2013, 11:52 PM
phat phrog stunt crew
like your walter avitar buzzard. 240 is a steal, not a deal.
03-30-2013, 07:40 AM
It really depends on the completeness of their work, the quality of the replaced parts and did they machine the drums. Check the itemized bill and see what they did.
Here's a list of what I always taught and did.
1. Clean bearings and check for metal flaking from bearings. If they don't do this they might have re-used defective bearings. I almost never use solvent to clean bearings. It's very difficult to remove all the solvent which will ruin the new grease. Wiping them out with a cloth will work. Hand pack bearings and replace all seals.
2. There are vastly different qualities of brake shoes and therefore vastly different prices. Cheap linings won't last and will glaze real soon and you will have poor braking. I always purchase linings from NAPA. They really care about quality.
3. Brakes work because of heat generated between the new shoes and the drum. The drum MUST ALWAYS be machined every time shoes are replaced. If you don't 50% of the braking equation is not correct. Some will tell you that it's not necessary. Some still tell you that a charged battery placed on a concrete floor will loose its charge over night. Common sense tells us that's an old-wives tale.
4. Usually drum brakes are only worked on after 50-70-K miles on vehicles. At that time I always replace all springs, and self-adjusters. TT's are different so I would not replace those parts unless some problems are spotted.
5. Following a shoe replacement you should have been advised how to properly burnish your shoes. If you were not advised then the shop is less than quality. Shoes/pads are burnished by stopping from around 40-MPH to about 20-MPH between 30-50 times allowing about a minute between for cool down. Most will not go through this specific procedure but actually you will in the process of carefully driving around even on your first trip. AVOID if at all possible smoking the shoes to speed up the process. All you will do is glaze the linings and ruin them.
JMTCW
TeJay
03-30-2013, 07:50 AM
JMTCW
TeJay
Sounds like a good way to burn up a new set of brakes.
Sure they need to be seated but 30-50 times???
I'll pass.........
Peace!
Dan & Rita D
03-30-2013, 07:54 AM
1. Clean bearings and check for metal flaking from bearings. I almost never use solvent to clean bearings. It's very difficult to remove all the solvent which will ruin the new grease.
TeJay
I simply use compressed air to blow the solvent out.
It is hard to inspect the bearings for wear unless they are very clean.
03-30-2013, 08:04 AM
Agree bakken, would be very suspicious if they were not cleaned with solvent to remove the grease and possible dirt/flakes in the nooks & crannies. I have a cleaning tank with solvent and use it and then wash them in SuperClean and hot water and then blow them out with compressed air. Takes about 30-45 minutes to clean/inspect 8 bearings. Also do the same for the drums, another 30 -45 minutes.
Thanks everyone for the info.
Rick
Reese Dual Cam
Honda EU2000i
03-30-2013, 08:08 AM
It all depends where you are. Last year while in BC had a bearing go on the TT. Went to a local repair shop (the only one in area). The replace the bearings, brakes, and drums plus had to turn down damaged spindle total rip off cost was almost $3000. When you are stuck on the side of the road you have no choice but to pay what the vultures charge.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
03-30-2013, 08:54 AM
arent these brakes self adjusting? wouldnt just backing up and braking like you would a car/truck with drum brakes work the same? sorry to hear caper that someone was willing to finance their vacation with your vacation money.
03-30-2013, 09:04 AM
In regards to the burnishing procedure. The burnish procedure is outlined by the DOT which has established the process to certify vehicle brakes when new models are being evaluated before production. There are specific stopping procedures that must be passed or the brakes will fail certification and the vehicles can't be produced. They state that burnish of brake pads/shoes is not complete until at least 200 or more proper stops are recorded. When completed the linings are properly burnished and maximum braking can be expected. Burnishing linings does not markedly or prematurely wear out the linings. It is intended to properly prepare the linings so that further braking, even hard braking won't glaze or adversely affect the ability of the linings to create heat.
This information came from reliable sources and I have read it in more than one place. Also it is not just something that so and so told me or I just heard it from another mechanic. It is what I know, taught and will do because it is based on reliable sources not just hear say.
TeJay
03-30-2013, 09:18 AM
Our dealer charged us $125 to repack the bearings in both axles.................
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
03-30-2013, 09:21 AM
Now the solvent issue. There' really nothing inherently wrong with using solvent. If you know what you are doing you will get all of the solvent out before you begin packing the bearings. Here's why I don't do it. For 35 years I did not usually wash bearings. I wiped them off and carefully packed them with new grease pushing out all the old grease. In all my years of doing it this way we discovered many, many defective bearings early by simply looking at the grease wiped off the bearings as they were taken out. Small metal flakes present in the old grease and bingo you have a bad bearing. No questions asked and you also know which hub it came from so you can remove the correct bad race. OK you take the bearings out put them into a solvent tank, get them nice and clean and examine the bearings. Bad rollers are easy to spot but early heating problems are hard to spot. I guarantee you would have seen metal flakes in the old grease immediately after removal had you wiped the grease off and looked at it.
By wiping out the grease you avoid time spent cleaning 2 sets of bearings and you've already determined if you need to replace any bearings.
I can honestly say that not using solvent never caused a bearing to come back to the shop as defective.
I also considered that if I advocated using solvent some future technicians running short of time and perhaps less careful might allow some of the solvent to remain in the recesses of the rollers. If solvent is designed to remove old grease I guess it would also remove or at least compromise new grease also.
TeJay
03-30-2013, 09:27 AM
Since self-adjusting brakes have been around since the early 60's I assumed that all drum brakes were SA. On our first camper we had a Lippert axle and they were not SA. Our current rig has Dexter and they are SA. It is also my understanding that the Dexters adjust either going back or forward.
TeJay
03-30-2013, 09:31 AM
Everyone has their reasons for doing it differently, been doing it since 1954 when we used gasoline and hot Tide water. Do each brg individually with the drum/rotor. Hand packed the brgs and still do except for a 'touch up' with the EZ lubes.
Did the same with engine blocks. When they came back from machine shop and were "Hot tanked", I would wash them with hot soapy water, dry and paint the inside un-machined surfaces with RustOleum Damp Red primer before starting re-assembly.
03-30-2013, 10:37 AM
Over the many years I devoted to teaching automotive I always tried to base decisions on the facts of the time balanced with common sense. When I started teaching in 1970 many of those facts changed and if one didn't keep up with those changes you fell behind. I remember using gasoline but I wouldn't do it today not so much because of the fire danger but because of how bad it would be for me to breath the fumes and absorption into the skin. I also never gave any thought to brake dust back in the 70's. In fact we advocated using the blow gun to get rid of the dust. Today I know better. I never had one of those fancy machines but I did use hot soapy water and it worked well. We all know asbestos has been out of brake lining since the mid 80's.
It makes no sense to not have shocks on a TT. It makes no sense to not use synthetic grease for bearings if it is even only 2 X's better than standard grease and I've read nothing to the contrary. Why not have self-adjusting brakes?? They've worked for years and years. Why should I have to re-pack bearings and adjust brakes every year??? If the grease will last and the brakes adjust leave it alone. Why open up a can of worms. Why not have disc brakes from the factory since they are much better than drum??
These are things that make common sense to me. Once I find out the real facts I don't do something just because that's what the industry says I should do. Remember the lawyers????
Coot, Besides washing the blocks I also chased the threads then blew out all other particles of dirt/dust. I never painted the insides I figured the oil would coat it all.
JMTCW
TeJay
03-30-2013, 11:08 AM
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
03-30-2013, 11:10 AM
...Coot, Besides washing the blocks I also chased the threads then blew out all other particles of dirt/dust. I never painted the insides I figured the oil would coat it all.
JMTCW
TeJay
Also radiused all oil return holes in the lifter galley to make the oil flow a lot easier and faster, especially on a sb Chevy in the front to get oil to the timing gear/chain and around the lifter return holes. Spent about 20-24 hrs doing this and "chasing" threads before assembly started. Had a 7' x 7' pressurized room in the corner of my garage for all this and the assembly.
03-30-2013, 04:37 PM
Remember this thread started with a simple question-- see post 1.
