Old 02-28-2014, 02:16 PM   #1
Crusader 325res tire pressure?
Just want to get some input on what other 325res owners are running. I have only had my 325res for about 3 weeks. I checked the pressures today and they were at 65psi. The factory sticker says 80psi. It was a little cold last night (31 degrees).
Thanks in advance.
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 03-04-2014, 04:59 PM   #2
I use 80lbs. Have over 7,000 miles on the tires. What size axle do you have, 6,000 lbs??
Bob & Sharon, '18 Berkshire 34QS, 2018 Jeep Cherokee.
btritschler1437 is online now   Reply With Quote
Old 03-04-2014, 05:34 PM   #3
Todouble's Avatar
80 here too on my crusader
Todouble is offline   Reply With Quote
Old 03-04-2014, 05:49 PM   #4
Thanks for the responses. I went ahead and used the recommended pressures it pulled great. One thing I noticed with the 325 vs the old 8280 while on the interstate and getting passed by semi's the push and suck was pretty much gone. Pulled Great.
Old 03-04-2014, 06:00 PM   #5
checca's Avatar
I use the max pressure on the side wall of the tire, on all my trailer tires.
2013 Lacrosse 318bhs
2010 Toyota Tundra Crew max 5.7 flex fuel / Installed airlift ultimate 5000 air bags and smart lift automatic leveling system.
Yamaha EF2000iS 2000 Watt Inverter Generators
Minooka, IL.
checca is offline   Reply With Quote
crusader, pressure, tire
