Old 05-11-2014, 06:53 PM   #11
The rather lengthy article I read about testing one indicated that it would have to be the width of the trailer to even begin to be effective. The most cost effective things are enclosed under body and a boat tail rear. Plus many newer fifth wheels are fairly aerodynamic to begin with. Think "round corners".
cadman99 is offline   Reply With Quote
Old 05-11-2014, 07:24 PM   #12
The one I had years ago came off a semi tractor and was not cut down width wise, it had curved sides/edges and did keep the bugs off the entire top of the trailer. I did get bugs on the lower 2'-3' that wasn't shielded by the truck itself. Being mounted on the rear of the topper, it was only about 4-1/2'-5' from the top of the deflector to the camper.
Old 05-12-2014, 12:13 AM   #13
Plain Old Member
Got any pictures of that set up OC? Sounds interesting.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 05-12-2014, 09:56 AM   #14
The eternal quest - better gas mileage. Give up - there is no easy or any way to greatly improve your gas mileage. Some fairly expensive modifications will make differences that are barely noticeable. If you are going to move a 10,000 pound barn door down the highway at 60 mph it just takes that much fuel.
