Old 07-29-2015, 04:39 PM   #21
Fulltime family RVer
Originally Posted by OldCoot View Post
First thing to do is to measure from front bracket to center bracket to rear bracket on the FRAME. They should be the same on both sides.
Ok, so sounds like I need to drop some of my under belly. I can't see all of the frame under there.
Old 07-30-2015, 07:42 AM   #22
Don't have to drop the under belly. Just measure between the fixed brackets.
Old 07-31-2015, 01:44 AM   #23
Crockett's Avatar
I seen more tires as of late lose the flatness of the cord body at the tread becoming round in shape if viewed in a cross section view. If the tires were breaking down in the fashion, it could account for the loss in distance.
Crockett is offline   Reply With Quote
Old 08-13-2015, 12:49 PM   #24
Axles moved?
Have you noticed any tire tread wear? I have the same problem and my right rear tire outside tread is worn down.
Vengeance13 is offline   Reply With Quote
Old 08-13-2015, 02:04 PM   #25
I didn't notice anything except for the spacing. I do now attribute that to flattened leaf springs over anything else.
I'm hopefully taking it in next week for a handful of work- new wheels + tires, new springs, maybe add shocks.
axle
