Old 10-14-2016, 01:28 PM   #1
Dexter axle grease caps
Had an AL-KO axle (3500#) replaced at CW. The replacement is a Dexter easy lube. To make a long story short, the grease caps will not stay on while traveling. One came off and busted the wheel cover (hub cap).
Anyone else having this problem?
skeet25golf is offline   Reply With Quote
Old 10-14-2016, 01:38 PM   #2
clr
No I have many miles on the Easy lube axles without this problem. Are you talking about the whole grease cap or only the black rubber cover for the grease zerk in the cap. If they are coming out you have gotten too much grease in the slot where the cap is taped into the axle. I would clean the cap and the slot on the axle that the cap is taped into. If that does not work try a couple of dabs of red grease seal adhesive.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 10-14-2016, 02:07 PM   #3
Left Coast
Someone may have removed it at one time and bent it.....my dealer sells them for $.90 a piece.....they're easy to dent installing, so I made a special tool to install them.......also, if one took them to a bench grinder and beveled the lip that fits into hub, it'd be easier to start them into hub straight The tool I made was to take a hole saw the size of cap at the ridge that sits against hub, when installed, bored a hole in a short piece of 2x4, then cut another short 2x4 piece to use against piece with hole and act as a surface to tap the cap in and not split the piece with the hole
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
bob caldwell is online now   Reply With Quote
axle
