03-06-2017, 01:17 PM
Disc Brake conversion
I am planning to convert my Dexter 7000# axles with neveradjust brakes to Disc brakes. After talking to the Dexter service folks they recommended that I buy axles with the disc brakes already installed. I found this a bit surprising. They say this will be less expensive than buying the conversion kits. Has anyone gone this route? Any thought would be appreciated.
GMC 3500 HD Dually
2016 Cedar Creek 34 RE
AirBox Revolution hitch
MorRyde pin box
Finlee Westie #5 (Door bell and security.)
03-06-2017, 05:10 PM
Left Coast
Still need the rest of the system....
03-19-2017, 08:53 AM
What price did Dexter quote you for the new axles? I would be surprised if it was less. But interested in finding out as I'm considering upgrading to disc brakes myself.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
03-19-2017, 09:00 AM
It would probably be less due to the labor charge to convert.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
03-19-2017, 09:13 AM
If you are doing the conversion yourself I doubt the axles are less expensive there are U-tube videos that show the conversion it is an extensive job but not beyond someone with a little skill
Retired Navy
2016 Flagstaff 26 FKWS
03-19-2017, 09:35 AM
Georgia Rally Coordinator
You should go down a few lines on this thread and read the Disc brake conversion done by several folks and cost around $2500. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
03-19-2017, 09:44 AM
I'm planning on getting the disc brakes installed on my Cedar Creek. Who did you talk to at Dexter? I might could save a few bucks. I think Dexter brought out Titan brakes. I'm going towards Goshen IN when I start out west this year, I could stop by
03-19-2017, 02:46 PM
I'm not a bit scared of tackling this simple job myself, but if a few bucks coukd be saved by swapping the axles, then I would consider it.
05-09-2017, 01:53 PM
Pulled the trigger today and ordered the disk brakes for our CC 36CKTS from Performance Trailer Braking, be at my location on May 16 to install while I get to watch and drink coffee.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
2014 F350 / 2015 CC 36 CKTS
05-09-2017, 01:57 PM
Let us know how it goes. I recently completed mine. I took several pictures during the process. Would love to see your install as well. Hope it goes well for you. Which hydraulic pump are you using?
05-09-2017, 02:07 PM
My trailer is way to light for needing the conversion however I think it is a great move for folks with the heavier 5th wheels and huge toy haulers, I would expect it to become an option offered at the factory in the future.
Retired Navy
05-09-2017, 03:09 PM
VERY happy with my disk brakes. Done on my driveway for $2,550 total.
Tom & Renée
Durham, NC
2021 Jayco Class C model 27U
05-09-2017, 08:02 PM
Same here, came to my house. It's like night and day different, best upgrade for me
05-09-2017, 08:18 PM
Well, I hitched it up today to make a little road trip/test of the new brakes. WOW! What a difference. No perceptible delay, and it felt that the truck and trailer brakes were acting in concert. That was a concern, because I would prefer to sacrifice the trailer brakes over the trucks. I pulled it up to highway speeds and made a few soft stops, followed by a firm stop, then pulled over to check everything. The hub temps were around 150 degrees, and the rotor temps were higher, but they cooled down quickly. Ambient temp was 86 degrees. I did notice that one wheel has the tendency to brake harder than the others, even to the point of that one tire wanting to skid. This might be because all brake surfaces and pads are brand new and are still breaking in. I will keep an eye on this on our first trip. All in all, I'm very happy with my $1300 investment. I used the kodiak dacromet hubs and the Titan EHB pump.
05-09-2017, 08:47 PM
$1300 seems like a super deal. Would you mind telling us in a little more detail what you bought where? Thanks.
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2019 F350 Platinum CC, PSD, 4X4, long box, SRW
Demco Glide Ride pin box
Demco Hijacker UMS 21K hitch
05-09-2017, 08:51 PM
Thanks Davidg for info and your test drive, here is what I am having put on, Ron took the order and sent me this list.
13" 7k Premier Disc Brake End Kit 8-6.5" BC, 9/16" Stud
4 228.00 912.00T K68-001-00
Brakerite by Dexter EHB 1500 psi
1 640.00 640.00T 068-344-00
Brakerite Mounting Bracket 1 37.00 37.00T 071-B19-00
Brake Line Kit Tandem Axle
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
05-09-2017, 10:26 PM
My fiver has 6000 # axles. I really wished that it had 7000's and I thought of swapping them out, but after having truck and trailer weighed at cat scale, i was ok with the 6k axles. My pin weight is 2700 +/-
So I found the Kodiak dacromet integral hubs/calipers and the Titan EHB at Eastern Marine along with a 3/16" copper/steel brake line kit.
So, hubs were $130 each x 4. Pump was $560. Brake line kit was $130. 3/16 double flare 4 way was $10. Double flare tool was $38. I already had tubing cutters and the tubing bender from Harbor Freight was $9. And I think the big bottle of DOT3 brake fluid was $10. Then I spent about $10 on misc cable clamps and self tapping screws, and still have most of them left. I already had the zip ties.
So, I guess it all adds up to just north of $1400. I put every wire connection in a junction box and soldered each splice before putting a wire nut followed by 3m electrical tape. Wires were clamped to trailer wall going in and coming out of each J-box, and I plan to laminate the wiring schematic and staple it to the wall close to pump, both Titans schematic and my own schematic of my part. I put together a small tool kit composed of a few 3/16 brake line fittings including a 2 unions, and 2 tees along with a few feet of tubing with a good double flare already on one end, along with a half bottle of DOT3 brake fluid, and the double flare tool kit, benders and tubing cutters. I taped the ends of the tubing shut just to keep the critters out. My brakes are important enough to justify carrying this stuff with me every trip.
05-09-2017, 10:34 PM
Great info. Thank You.
