Old 06-13-2016, 08:47 AM   #31
leefl's Avatar
I'm very skeptical about the physics of this. It's early in the morning, so I'm probably not thinking clearly, but ...
Wouldn't centrifugal force try to always push the beads to the outermost part of the tire, which, since it is furthest from the axle center be the "heavy" side of the tire, and thus exactly the opposite of where you'd want any weight added ?
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 06-13-2016, 08:50 AM   #32
I can't explain the ohysics, but, on YouTube there are videos of how they work, using clear bottles to show the beads movements.
I know the use of them prolongs tire life on motorcycles tremendously.
I will be installing new tires within the next few weeks and plan to add beads then.
Sent from my SM-G900V using Tapatalk
2010 Surveyor 28 BH
2007 Chevy Silverado Classic
4.8 with Bully Dog Gas Tuner and 3.73 gears
Super Coop is offline   Reply With Quote
Old 06-13-2016, 08:55 AM   #33
Commercial Member
If you add "balance beads" just be sure you confirm the addition of the beads does not void any tire warranty.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 06-13-2016, 10:48 AM   #34
I don't know how: but I can tell you they work. I also have them in my 285 x 70 x 17 E rated truck tires, 2nd set and have been running them now for over 4 years with NO other weights on the tires and they are smooth as silk at least up to 80 MPHs. Have not driven faster than that.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 06-13-2016, 10:55 AM   #35
They have been up to 105 on my MC and never a wiggle. Not proud that I had to go that fast to avoid dump truck that was pelting me with rocks, but it happened, once.
I have never heard of anyone having issues with them causing issues unless ocassionally a bead will get in the valve stem when checking air pressure. Then it sometimes is hard to get it out. On the MC I just roll valve stem to down position, that's a little harder on a camper.
Beads take a 10,000 mile MC tire and will get 20-25,000 out of it.
2010 Surveyor 28 BH
Old 06-13-2016, 01:32 PM   #36
Commercial Member
Whoever is selling the beads should inform you of the need for the special valve "filters".. I have heard of "dust" from some balance beads cloging TPM rendering it useless.
tire
