Old 12-29-2016, 08:03 PM   #1
Failure is my business
2Evil4U's Avatar
Dissecting an OEM Travel Trailer Tire
Based on what my old Tires looked like before I swapped them out for Maxxis 8008's I decided to cut one apart to see if I could find any other issues that might lead to additional delamination problems like the one that caused my blowout.
First, I was surprised at how easy the tires were to cut up. Especially the sidewalls. Next, I picked a spot based on rolling the tire and looking for a high spot. I did find a section of delamination in the spot I cut. I was not too impressed.
I'll say it again. I completely understand the people who said they immediately replace the factory tires when they buy a new trailer.
I made a video of the process if you're interested in what I did and what I found.
https://youtu.be/TiyINVp4RCo
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilstein 5100's Derale oil cooler, 97 F150 4x4 5.4L 278,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
Days Camped: 2016: 43, 2017: 83, 2018: 44, 2019: 78
2Evil4U is offline   Reply With Quote
Old 12-30-2016, 02:24 PM   #2
Airdale's Avatar
Tread separations are complex in nature. However, experts such as Dr. John Daws are very successful in determining their causes.
http://dawsengineering.com/linked_fi...eparations.pdf
A Trailer Tire Poster
Airdale is offline   Reply With Quote
Old 04-15-2017, 11:34 PM   #3
pbrackney's Avatar
What brand were your OEM tires that you replaced?
Philip, DW, 3 DD, 1 DS, and Ginger our Dog
2017 Wildwood 30QBSS
2003 Ford Expedition 5.4 Liter with 3.73 Axle
Equalizer 4-Point Sway 12000# & Tekonsha P3
pbrackney is offline   Reply With Quote
Old 04-16-2017, 06:56 AM   #4
2007 WildCat 32QBBS
18CrewDually's Avatar
Great video showing the poor quality of a trailer tire. And you'll still get people defending the junk and trying to put blame on the operator as if you did something wrong. I think a brand new one you would find those voids. LT's are all I run.
18CrewDually is offline   Reply With Quote
Old 04-16-2017, 04:44 PM   #5
2Evil4U's Avatar
The OEMs were Castle Rock D's. I replaced them with Maxxis E's balanced with dynabeads. Love the new tires.
Old 04-16-2017, 05:05 PM   #6
northstar1960's Avatar
the main reason i replaced my brand new TH tires is they were woefully under rated to the weight of the loaded TH . if they had been a giher load rating i most likly would have kept them . one must keep into account that most TT have tires that barely if at all meet the load of the loaded TT . this can also be a big reason for failure
northstar1960 is offline   Reply With Quote
Old 04-22-2017, 11:04 AM   #7
f5moab's Avatar
The video doesn't really show anything without a comparison. Need to cut up a new tire to find out if there is any difference.
f5moab is offline   Reply With Quote
Old 04-22-2017, 04:38 PM   #8
Commercial Member
Agree. Not sure why he didn't bother to read the material listing on the tire sidewall. No mention of Fiberglass means no Fiberglass in the tire.
"I think there is metal in the tread" again read the sidewall.
Same for sidewall Polyester cord. What is the strength per cord of the polyester of this tire vs a similar size Goodyear or Michelin? The fact that it is possible to cut the sidewall with a razor blade box cutter knife means little unless he can demonstrate the same can't be done on a 1st class USA made tire.
Fiberglass wouldn't work in the sidewall as it can not tolerate the level of bending sidewalls experience.
Comments on the "small gauge" of the high strength bead wire. Not sure if he was expecting a single hoop of steel but it would be almost impossible to mount a tire as unless you have a multi-istrand hoop you can not oval the bead to "button hook" over the rim flange. Where is the comparison data? What is the tensile strength of the bead wires in this "junk" tire vs a 1st class US made Goodyear?
"Rubber didn't vulcanize together properly" is based on experience of examining how many hundreds of tires that have been in trailer service with the high Interply Shear forces?
How many miles at what load and what speed & inflation were these tires run?
Would it be better if there was no detachment at the belt edges? Yes of course but we have no idea of the tire use so have no information on probable cause for small detachment.
Maybe the main reason is the selection of tire capacity by the RV company. Look at his comparing the tires on a U-Haul trailer with RV application. I've been suggesting 85% actual load as the max percent of tire capacity Also no speed faster than 65 and always run tire max inflation to lower the Interply Shear.
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
Tireman9 is offline   Reply With Quote
Old 04-23-2017, 03:32 PM   #9
RetiredRVer
X2, Tireman 9. Listening to a non-expert layman discuss tire issues on video, is the same as reading all the opinions written here on the forum. Everyone has an opinion about the tire problems related to the pull behind RV industry....his holds no more weight then the others we have all read here. I put much more reliance on your opinion about tires, because you are a tire expert. Thanks for weighing in on the video!
Joe & Sandy
Mentor, Ohio
2017 Ram Laramie Longhorn Crew Cab 4X4 Cummins Diesel
2017 Coachman Chaparral 336TSIK Fifth Wheel
2018 AT 18 Alaska group
checkmate99 is offline   Reply With Quote
Old 04-23-2017, 03:57 PM   #10
Iwannacamp's Avatar
X3 Tireman
2017 Puma 297RLSS
Old 04-27-2017, 11:50 AM   #11
an interesting video and info Tireman.
But I would argue (guess?) that speed and tire pressure are the larger issue for most blowouts. If the main issue is the load range, then we would see many more blowouts.
I'm always amazed when I'm towing (driving 60 MPH in the right lane) and someone blows by me at 70 MPH+ pulling a large trailer. Just because you can drive that fast without sway doesn't make it a good idea.
That said, exceeding the speed range for the tires while also loaded to 90% + of the load range probably compounds the issue. Maybe if you had a higher load range tire then you could exceed the speed range without a blowout.
But my main point is to say that we don't all need to go out and spend a bunch of money on brand new (higher load range) tires for our brand new campers.
Treat the camper right, replace the tires before you hit 5 years, and you will most likely be OK.
mkosu04 is offline   Reply With Quote
tire, trailer, travel, travel trailer
