Old 09-11-2016, 02:51 PM   #21
Blog: RVroadtripper.com
hbillsmith's Avatar
When we took our 2016 Wildcat on its first shakedown weekend after pickin up at the dealer, I noticed that all the rear crunch cushions were bounced down to the floor when I arrived. Repacked them back in the couch at camp and then headed home. Once home noticed they all bounced off again and it was a short 100 mile trip! Few weeks later had it back at the dealer for a short list of warranty fixes (nothing major and all were fixed). I asked to have the alignment and balance checked while they had it. They took to a nearby Discount Tire chain store and had the 4 tires balanced. Amazing! Couch cushions now stay on the couch even after thousands of miles towing.
Maxxis 16" E; Ride Rite AirBags w/AirLift 1 wireless compr; Adv.Folding 4 Cover Andersen Ultimate II Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball LCI Ground Control 3.0 4pt + 2pt Elec.Rear stabilizers; 3 Slidecovers; 10ft. Portabote 6000# Dexters; mor/Ryde CRE3000 w/HD Wetbolts; King Dish Tailgater; 5hp Outboard Dual A/C; Furrion 48 Rear Camera; Champion 3100 Inverter w/Extended Run
hbillsmith is offline   Reply With Quote
Old 09-11-2016, 02:58 PM   #22
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
If your farm utilities are tagged and used on the roads at higher speeds, yes, you DO need them balanced. I grew up on farms in Vermont,,,,,and if they weren't taken up to higher speeds, no need to balance them. ....But you're pushing your luck if you take them up to higher speeds without balancing. I speak from my personal experiences.
Grampa Jim is offline   Reply With Quote
Old 09-11-2016, 03:08 PM   #23
2007 WildCat 32QBBS
05CrewDually's Avatar
Originally Posted by Dogpound View Post
Farm trailers aren't driven on the road very much. Besides they don't get tags or have the lights working. So why should they balance the wheels, cost to much
I think you're thinking of a hay wagon. We always balance trailer tires.
05CrewDually is offline   Reply With Quote
Old 09-11-2016, 04:33 PM   #24
Really...they don't around here. You should see some of the live stock trailers here. I back off a couple of hundred yards...my feeling is they probably don't have brakes either
Dogpound is offline   Reply With Quote
Old 09-11-2016, 05:16 PM   #25
ARLO
Always!!!!!
rlocicero is offline   Reply With Quote
Old 09-11-2016, 05:26 PM   #26
I have read in the forums that the typical tire shop uses the center hole in the wheel to mount it on the balance machine. Supposedly the hole in trailer wheels may not be concentric with the rim thus throwing off the whole balancing operation. There is an adapter that centers the wheel with the lug nuts but is apparently difficult to find. I have no idea if this is true or not, it's just something I have read.
2015 GMC Sierra 1500
2013 Heartland North Trail 28BRS
spudston is offline   Reply With Quote
Old 09-11-2016, 05:32 PM   #27
As I've said a couple of times on other threads, "for every solution, there is a problem". They've been balancing tires using the center hole for years and years, the center hole is punched/formed at the same time as the stud holes.
Old 09-11-2016, 07:07 PM   #28
Originally Posted by youroo View Post
If anything rotates,"Balance It"! Vibration is a Killer! Youroo!!
Ditto
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
SilverArrowPro is offline   Reply With Quote
Old 09-11-2016, 07:53 PM   #29
Does FR balance them at the factory? I don't recall seeing any balance weights on the new tires.
Cedar Creek Lake, Texas
2016 Wildwood Xlite 171 RBXL
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
Old 09-11-2016, 08:05 PM   #30
Iwannacamp's Avatar
This has gotten me thinking...scary.
I am driving 1000+ miles on the way back from pick-up. I should prolly make sure they are balanced or get them done. Good idea?
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Days camped 2016 8 2017 1
tire, tires
