12-17-2017, 11:38 AM
Always Learning
Drove over curb- busted up suspension
12-17-2017, 11:48 AM
Holly crap!!! curb really did a number. Hope that you can get that fixed with out breaking the bank.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
Always Learning
12-17-2017, 11:49 AM
OUCH!
Good luck
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
12-17-2017, 11:50 AM
Always Learning
12-17-2017, 11:56 AM
The zip ties your so famous for aren't going to fix this one. Sorry just had to say it. Good luck.
2014 Forester 3051s
2012 Sonic toad
12-17-2017, 11:59 AM
Location: Alberta - East of the Rockies, West of the Rest
Ouch, this surely ruins the day and I hope you can get it fixed without breaking the bank.
You may want to keep a close eye on the tires on that side from now on.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
12-17-2017, 12:24 PM
Wow...not so great welds on that shock mount. Was that from the factory?
12-17-2017, 12:26 PM
Always Learning
True, nor does my unlimited supply of gorilla tape.
I’m not against buying chain and trying to tie it up- but I need to figure out wtf that really means.
Fortunately, different memberships should cover the service visit and fix cost. The bigger problem is I’m stuck because it’s Sunday. Can’t find someone to come to me.
The spring mounts are welded to the frame and part of it busted off. I don’t know the first thing to getting it resolved on my own.
12-17-2017, 12:42 PM
Sorry, man! Yeah, this is not a DIY project. They have to get the weight off and then they probably can't weld it right back to the same broken spot. They may have to weld on a good strong backing plate to attach it to. Good luck!
2016 FR Forester 2401R
Towing 2014 Honda CR-V
12-17-2017, 01:10 PM
Always Learning
Well fortunately, I looked a bit closer. It’s definitely JUST a broken leaf and everything else is intact- the hanger and all. No welding required.
Good/driver’s side:
Broken side:
12-17-2017, 01:12 PM
Always Learning
No, shock mounts were aftermarket.
12-17-2017, 01:33 PM
Recently new!
E'dad, unbolt the dangling spring. Lift rig by the frame and block it with wood-2x4, 6x6 or as needed. Set back on axle/frame. Wrap all with chain and bind as best you can. Should allow you to limp to a safer spot until you can get a replacement leaf spring.
You may opt to replace both on that side.
Good luck!
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
12-17-2017, 01:43 PM
I remember my brother getting a leaf spring replacement at Tractor Supply on day when he had the same problem.
12-17-2017, 01:46 PM
Whoever that is, don't let them work on your trailer again.
Also, hope that isn't gas running through that pipe under your trailer.
12-17-2017, 01:51 PM
Could any of that be the result from the previous frame work you had done ?
12-17-2017, 01:54 PM
Scoundrel
Ya know, there's something there that doesn't look right... The top leaf broke right where the ends of the second and third leaf(s) in the stack terminate. The second and third leafs should not terminate in the exact same place as shown in the photo of the good side.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
12-17-2017, 01:55 PM
Always Learning
Sounds like a local TrueValue has a 3,300 lbs leaf spring that might work. But I’m hopeful the mechanic can get the right part.
12-17-2017, 01:56 PM
Always Learning
Good luck!
Thanks Paulie. Now I have the info if it comes to that.
12-17-2017, 06:00 PM
Good news, at least to that extent!
