Old 10-01-2016, 08:30 PM   #1
Rokslinger's Avatar
Dumb tire question
This may seem like a dumb question, but I don't take much for granted and I can't find a direct answer on the manufacturer web sites. My toad is a Jeep Patriot with a factory installed tire pressure monitor system. Obviously, it does not register in my motor home, nor is it operational with just the accessory key on in the Jeep. I want to put a TPMS on the motorhome and put sensors for the same sytem on the jeep. Is this how it is generally done? Does having an aftermarket TPMS on the Jeep conflict with the OEM system? Will this work Ok? Thanks for your wisdom and experience.
Dave Hammond
2017 FR Forester 3011 DSF
2013 Keystone Raptor TH
2013 Ford F350 Dually TV
Rokslinger is offline   Reply With Quote
Old 10-01-2016, 09:50 PM   #2
I don't know the answer but you might call up TST or greatrvproducts.com
spock123 is offline   Reply With Quote
Old 10-01-2016, 10:06 PM   #3
rsdata's Avatar
IMO
I would bet that the TST 507 TPMS would work just fine on the TOAD...
there should be NO interaction between OEM and add-on systems...
I have a RAM with factory TPMS and still pull my trailer with the TST 507 system...
IF the TOAD sensors do not register you can add the accessory antenna to get the signal up front in your cab...
2014 Shamrock 183
Old 10-01-2016, 10:14 PM   #4
trbomax's Avatar
Or just buy a good quality tire gage and learn how to use it.
trbomax is offline   Reply With Quote
Old 10-02-2016, 12:10 AM   #5
SKnight's Avatar
As stated, the aftermarket and OE systems should play nice side by side. They should be on difference frequencies and shouldn't even see each other.
The OE sensors broadcast the whole time they're rolling down the road even with the vehicle off, I've often wondered why there isn't a system that can read the OE system as well as the aftermarket.
Old 10-02-2016, 06:52 AM   #6
That's great to always check your tires but since I can't see the tires back there a good TPMS is the way to go.
Old 10-02-2016, 07:28 AM   #7
Hard to do when you're going down the road.
Old 10-02-2016, 07:29 AM   #8
SeaDog's Avatar
That used to be my thinking also until I blew what I thought was a good tire on my class A and did a ton of damage. I would not have a motorhome or travel trailer without it now.
to answer the OPs question I believe adding the non-pass thru senders (so you don't have to rebalance your tires) to your car should not cause a problem.
Retired Navy
2016 Flagstaff 26 FKWS
tire
