Old 05-11-2016, 05:23 PM   #1
Domtherrien's Avatar
Easy lube bearings.
Looking for some info. I currently have a standard setup right now. To my knowledge. I am quite capable of tearing down and repackaged etc but wondering how much of an issue it would be to convert to this setup for simplicity sakes.
2011 F150 Super Crew Ecoboost
2015 Salem 27 DBUD
Domtherrien is offline   Reply With Quote
Old 05-11-2016, 05:38 PM   #2
2015 Salem 27 DBUD
Each end of your Axles would need to be drilled! Youroo!!
Old 05-11-2016, 06:07 PM   #3
So essentially a pain in the ass a lot of unnecessary work. I'll stick to a few hours of playing around in the garage doing this. Thanks muchly.
2015 Salem 27 DBUD
Old 05-11-2016, 06:08 PM   #4
Who Dares, Wins
doc73's Avatar
Would drilling them even do this? I would guess the hub would also already need to grease passages drilled or molded into the hub to force the grease to the rear of the hub and out the front.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 05-17-2016, 09:57 AM   #5
schrederman's Avatar
These are done at the factory with tooling, and would be pretty hard to do by hand.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 05-29-2016, 10:59 AM   #6
dbarr's Avatar
Name:	ImageUploadedByForest River Forums1464537364.823717.jpg
I'd say that this hole was drilled before the lathe work.
'15 F150 Ecoboost Maxtow Scab '13 Freedom Exp. 233RBS
Days camped 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....52
dbarr is online now   Reply With Quote
Old 06-06-2016, 06:10 PM   #7
Old Member
EZLube should stay on boat trailers. Believe me, even if you have EZLube, you should pack them by hand. If you don't, one day you will be cleaning up a mess and replacing brakes hoes.
Cool Canuck is offline   Reply With Quote
Old 06-07-2016, 08:32 AM   #8
I think we're talking about two different things here... There are Dexter Easy Lube bearings and Bearing Buddies.
Easy Lube are part of a Dexter axle and have a grease zerk under a rubber plug in the center of the axle axis. When you force grease into it it goes down a hole to be expelled inboard of the inboard bearing and oozes out through the two bearings until you see new grease around the zerk you are filling from.
Bearing Buddies are an add-on that replaces a regular bearing cap and is meant to have grease forced into the cap. but there is no exit for the grease except for out of the inboard seal and potentially onto the brake parts.
I don't think you can retrofit Easy Lube parts onto a non-Easy Lube axle.
matwiyj is offline   Reply With Quote
Old 06-07-2016, 08:50 AM   #9
Just A Member
EDABEUT's Avatar
Ok so what about repacking wheel bearings on these new RV's. How often do you check and repack them?????? What has been your experience with factory bearings and if they were packed correctly to begin with. I use to check mine every year and repack every 3 years. Anybody had any bearing failures ??????
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
EDABEUT is offline   Reply With Quote
Old 06-07-2016, 09:21 AM   #10
Restcure's Avatar
It's my understanding that pressure from the grease can force out the rear seal; when we're greasing our EZ-lube axles we spin the wheel periodically to distribute it. It does take a LOT of new grease to displace all of the old... almost a whole cartridge for each hub.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
bearings
