Eezee Tire Pressure Monitor System problem
Bought the 6 sensor system for my Class C, installed with no problem and everything was working fine. Woke up the next day to start a trip, turned on the RV, and the left rear outside tire was reading 11 psi! I checked it with a gauge to make sure it wasn't a sensor problem and it was low. Took that sensor off as I wanted to get going on my trip. At the end of the first day the front left tire started to slowly lose air! Took all the sensors off as I wasn't trusting the system at this point. I know I screwed all the sensors on tightly, didn't use the anti-theft feature as I wanted them to be as light as possible. Anyone else have this issue with Eezee or any other brand? My RV dealer doesn't like using sensors, says they're problematic.
