Old 08-06-2011, 12:15 PM   #1
HONDAMAN174's Avatar
Electric brakes
Still getting used to my TT. Have a 2012 high wall 277 and find that the brakes are a little grabby. Have dialed back the brake controller but still feels weird. After driving only a few miles, one brake drum is rocket hot and the other I can put my fingers on. Is their an adjustment to make?
Just glad to get away
Old 08-06-2011, 12:21 PM   #2
jimh's Avatar
the brakes can be adjusted. u may want the dealer to look at that; there may be another problem in there.
jimh is offline   Reply With Quote
Old 08-06-2011, 12:28 PM   #3
Yea... Wish the dealer acted like they care
Old 08-06-2011, 12:28 PM   #4
KyDan's Avatar
YES!
Don't drive it if you have a really hot drum. You can damage the brake or
even cause a bearing or wheel failure.
It needs adjusting.
The adjustment is fairly simple if you're inclined to do it or take it to
the nearest dealer soon.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 08-06-2011, 12:53 PM   #5
jimh's Avatar
i believe the reason i'm concerned is that that trailer had to be delivered to the dealer. i don't see how the brake could have been tight for that distance. i would pull it and inspect it. if u have problems pulling the drum, it is too tight.
the other half is that i don't think u would actually feel the grab if only one brake was grabbing. u may have other problems...a bearing? worth a look to make sure.
Old 08-06-2011, 01:17 PM   #6
Always willing to learn. Where would I find the basics on adjustment?
Old 08-06-2011, 10:39 PM   #7
jimh's Avatar
abt the 2 post under general tech and repair, there is a post abt "ultra lube axles and bearing procedure". if u scroll down there are a couple post with pdf attached. what ur looking for (bakes an bearings) is there.
at the bottom of the rear of the hub, is a oval rubber plug (actually rectangle with rounded ends). pull that plug and u will be able to see a star wheel. rotate that to tighten or loosen the brakes. there is a special tool or u can use a screw driver.
u will need to jack the wheel to be able to check for drag. a small amount is normal.
before u start, with the wheel jacked up push the top of the wheel in and out and check for play in the bearing. u should be able to feel something but it will be barely noticeable.
sense it appears that it is only one giving problems, u may be able to compare the play and the rotation drag against the one not giving a problem.
if u go to the point of pulling the drum, when u put it back together, i believe they tell u to back the nut something like thousants, for that i would back off 1/4 turn then increase that until u can put the carter pen back in. i wouldn't back off more than 1/2 turn. u need room for the bearing to expand.
with only one giving a problem, i would highly recommend pulling the drum and inspecting the bearings and brakes. it could easily be something other that a dragging brake shoe.
if u haven't pulled one, the one nut on the axle is the only thing holding the wheel on. keep everything clean. on the bearings ur looking for discoloration of metal from over heating. normal is silver and shinny. run u finger around them and see if can see or feel pitting. pitting isn't good. check the brakes and assemblie and see if anything looks wrong ie maybe a spring broke or came loose.
above all, before u get into any of this, pump some grease in there and see if ur problem goes away. there have been a few post abt the factory shipping the axles with the bare min of grease in there. one other person wrote abt having his hubs get hot and pumped grease in and solved the problem. on the grease, u pump slowly until it starts coming out around the nut near where ur pumping it in. i believe ur going to be surprised at how much it takes to fill it.
Old 08-07-2011, 02:32 AM   #8
Nigels's Avatar
Hey Hondaman174 what Honda do you have?
Nigel & Bev
Brit Driver & Canadian Naviguesser
We summer in Maple Bay BC Canada & winter in Monchique Portugal
2011 Rockwood Signature Ultra Lite 8280ws 2011 Dodge Ram 3500 4x4 Diesel
Nigels is offline   Reply With Quote
Old 08-08-2011, 09:11 PM   #9
2011 Pilot (tow vehicle)
2010 Accord (race track toy)
Old 08-08-2011, 09:41 PM   #10
Nigels's Avatar
Hey post some photos of the Accord!
Nigel & Bev
brakes
