Old 01-07-2012, 02:42 AM   #1
electric stabilizer jack problem
Hello,
I just bought a 2012 Surveyor. At walk through, the technician demonstrated the front stabilizer jacks. When I arrived to destination, unhooked and pushed the button, nothing happens. Rear jacks work fine. Is there a reset or fuse?
michellemge is offline   Reply With Quote
Old 01-07-2012, 05:51 AM   #2
I am pretty sure there is a fuse. Check the breaker panel for a thrown breaker and for a bad fuse. Check the wiring around the stabilizers for a fuse. I am sorry I cannot help more than this, but this is my first TT with power stabilizers and I have not had the TT but for about the 3 weeks.
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
Old 01-08-2012, 07:16 AM   #3
Herk7769's Avatar
There is a fuse. It may even be "manually" reset-able or a 30 amp single blow. It is located within 18 inches of the battery usually off the load side terminal of a larger current limiter that protects the entire camper's 12 VDC load. (see attached)
I would take a trip to your local auto store and buy an automatic resetting fuse. The bottom photo is what you are looking for if you currently have a single blow type. (DO NOT break off the snap legs as you need the length. The cover will not close over the replacement anyway so you will have to wrap it in electrical tape.)
HAM CALLSIGN - KC3FFW
Old 01-08-2012, 07:27 AM   #4
Herk7769's Avatar
There is nothing in the panel for the main slides or front stabilizers; just fuses near the battery.
The REAR stabs are a different story. If your REAR stabs are not working the problem fuse may not be there at the battery. There might be an auto-reset fuse located near the switch for the rear stabilizers. Like inside the entertainment center cabinet in our camper.
Hidden circuit protection rear stabilizers pictures from travel photos on webshots
OR
It could be in the fuse panel itself like:
Lower CB Panel pictures from travel photos on webshots
OR
It could be a pigtail fuse just stuffed behind the power distribution panel itself.
