Old 10-02-2016, 08:40 AM   #1
Electric stabilizers Flagstaff Super V - still shaking
My 2016 27vrl has the electric stabilizers on the four corners. I added 24" BAL manual scissors to the front and it helped up front a little. My leveling procedure is to have drivers side slightly higher cause all slides on that side. I then let down stabilizers on that side, extend the slides, then deploy passenger side stabilizers.
The thing still shakes left and right as if on a center axis.
I bought two 30" scissors wanted to put them behind the tires but enclosed belly not sure on attachment. I noticed when setting up last Thursday that the center of the power stabilizers, the bar that holds the screw that spans the width, bows when the movement occurs. Should I put the 30s in the back? In place of the power ones or at the factory spots under back bumper (factory mounting point un-used).
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 10-02-2016, 03:31 PM   #2
Well... I see one problem...the part the power Jacks bolts too has too much give.
electric, flagstaff, stabilizers
