Old 10-12-2015, 12:44 PM   #1
23ss ROOster
Wags2237's Avatar
Electric tongue jack problem
It has stopped lifting or letting down tongue. Has power but fails to operate up and down. Had to finish taking TT off hitch manually. Repairable or buy another one? 3 years old on it. How much if new? DIY take off, on or need to take in? Any suggestions appreciated.
2012 23SS ROO
2014 Ford 4x4 F150 XLT 302A, screw, Ecoboost, 3.73, max tow, off road pkg., 36 gal tank, Ruby Red, tailgate step, Linex spray in, Truxedo bed cover, 30% front tint, Viper remote start, 1000 lbs WDH
Wags2237 is offline   Reply With Quote
Old 10-12-2015, 12:59 PM   #2
Not much Info but just buy a Barker jack! Youroo!!
Old 10-12-2015, 01:16 PM   #3
jeff64's Avatar
Just because you have power to it doesn't mean you haven't lost ground. With either 12v test light or voltmeter, go from the jack housing to the frame near where it is bolted to. Have someone activate the lift. If you see voltage on the meter or the lamp lights, you've lost ground. You should be seeing no light and no voltage.... take it off and clean up metal grounds and be sure the star washer is between them.
BTW youroo has a good reccommendation , the Barker HiTorque recirculating ball jack is a winner. Still got mine from the trade in and will hang onto it as a spare when whatever brand FR put on the new TT
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 10-12-2015, 01:40 PM   #4
Brother Les's Avatar
should be fixable. Block the front up where you can safely work on it and it is holding no weight.
Brother Les
Old 10-13-2015, 11:30 AM   #5
We had a similar problem this summer - our trailer, which we bought used, came with a Barker 2500 jack, which wouldn't raise up. Called Barker and it turned out to need a new toggle switch, that was $18. The guy there was really helpful. If yours is a Barker, you can call them and he can troubleshoot.
dawnco is offline   Reply With Quote
Old 10-13-2015, 11:41 AM   #6
Sounds like if you have power into the head, then you have a bad switch.
Replaced many and the are easy to do. get the switch from your dealer and just switch one wire at a time. Or take the head into the dealer and ask them to install new switch.
hillsdaletc is offline   Reply With Quote
Old 10-13-2015, 12:02 PM   #7
Stormrider151's Avatar
I had a Bull dog jack once that when you activated the switch the motor would run but just made a clicking noise and wouldn't move up or down. Stripped gears. It happened at the dealer and they replaced it for free.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 10-13-2015, 12:03 PM   #8
Betting it is the switch. Happened to mine, One wire at a time cause there are sevenral wires on it.
James Briar is offline   Reply With Quote
Old 10-13-2015, 05:10 PM   #9
Captn.Ken's Avatar
I had failure and discovered that even though I had power, my ground was faulty. Removed ground wire and cleaned surface. Been working fine for a couple of years now. Check your ground for connectivity.
Captn.Ken is offline   Reply With Quote
electric
