Old 03-22-2015, 08:37 PM   #11
geotex1's Avatar
That's definitely a get it together to get you home repair... Been there, done that, twice... Honestly, a replacement axle is cheap enough. Around $100 naked if you already have bearing sets coming and brakes and hub drums good. Wouldn't think twice about the tiny investment for peace of mind personally. Find your local trailer shop to order and buy without highway robbery.
geotex1 is offline   Reply With Quote
Old 03-22-2015, 09:02 PM   #12
TURBS's Avatar
Check e trailer for competitive prices.
Old 03-22-2015, 10:31 PM   #13
Crockett's Avatar
Well the OC and me could prolly run it, but ANYBODY less frugal would replace it. LOL...
Crockett is offline   Reply With Quote
Old 03-23-2015, 12:46 PM   #14
Of course its not common so I need to order it. Al Ko could build a bare axle for $96 but shipping almost triples the price. So I'm checking the local dealers for a price. Its a 3500 lb axle 76 hubface 57 spring center with ez lube. Eastern marine has the size but list it with a spring center of 58-66. The person I spoke to there said if I set it at 57 the warranty is void.
KenW is offline   Reply With Quote
Old 03-23-2015, 02:37 PM   #15
My suggestion would be to check with a trailer builder in your area, someone that builds trailers can fab an axle up that would meet or exceed builders specifications.
2012 Dodge Ram 2500 Limited 4x4 ramboxes
2012 Chevy Tahoe
2011 Yamaha Venture
Wildwood 241QBXL
dacheedah is offline   Reply With Quote
Old 03-23-2015, 02:41 PM   #16
Crockett's Avatar
my vendor stocks them in 2 inch increments. I just get longer or shorter to fit, and weld my pads...
Old 03-23-2015, 02:44 PM   #17
TURBS's Avatar
This place is close no?
http://www.erbtrailer.com/index.html
Or here in Sarasota.
http://www.trailerdepotofsarasota.com/
Old 03-23-2015, 03:24 PM   #18
Send a message via MSN to Tiggerdad
The important dimensions are where the lip seal is, the radius on the shaft for the back of the inboard bearing and the diameter of the shaft where the bearings run. Until those are checked you don't know how well the bearings would run. That lip seal area is damaged and may damage a new (double lip) seal. There is a thin sleeve called 'Speedy Sleeve" available at bearing distributors that fits over the seal area and provide a smooth place for the seal to run.
IMO, the dealer shafted you and should replace that axle. If it were mine I would replace the axle
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is online now   Reply With Quote
Old 03-26-2015, 08:11 AM   #19
New axle ordered and should be here in the next couple weeks. I showed the axle to a guy at one of the trailer places . After running his hands over it he was amazed it held up for more than a couple miles.
