05-24-2019, 10:10 AM
Explain my axle to me
I have a Lippert tandem axle trailer. Forgive my complete ignorance on how to describe it, but the wheels have “movement” That is, they can pivot from side to side and aren’t fixed on the front to back plane. But if I’m making a tight radius turn they will “pop”. A lot. Is that normal?
I vaguely remember the tech on my PDI mentioning that these are prone to blowing some seal but it would be obvious if that happened because the rim would have (grease?) all over it.
Can someone give me the axles for dummies basics? Thanks.
2021 Cherokee Alpha Wolf 23rd TT
2016 F150 4x4 Sport
05-24-2019, 03:49 PM
Retired Old Fart
Look at the frame around the axle hanger plates. Look for obvious cracks in the steel or even cracks in the paint (which is actually a powder coat, but it will let in road water with salts if cracked and cause the steel underneath to fail). That is the issue I had with my popping sounds.
If you frame is solid, then I would suggest inspecting the bearings. When was the last time you inspected or repacked the bearings?
This is an example of what you *DON'T* want to see on your frame. This was mine (one of several places) before the factory repair.
Just the 2 of us in a...
"Currently between trailers"
Sold the 246RKS in 2023
05-24-2019, 04:09 PM
I had the bearings repacked before the season last year. The trailer was only two years old then and less then 3000 miles on it. They said everything looked good.
I just checked the frame and didn’t see anything surprising.
The popping sound seems to be coming from where the hubs connect to the axle crossbar (again. I apologize for not knowing what I’m talking about here) and seems to be related to the “flexing” that the hub does.
If I’m making a tight turn (in my cul-de-sac, for instance) the wheels will flex as much as 10-15 degrees off center.
2016 F150 4x4 Sport
05-24-2019, 05:21 PM
Are you sure the popping sound isn't coming from your WDH?
The grease comment from the tech may be regarding the EZLube hubs if you have those. They're prone to blowing seals if not done properly and maybe even when done properly. I don't want to hijack this thread on that topic.
2019 Rockwood 2902WS
2019 Ford F250 4X4 CCSB 6.2/4.30
Equalizer E2 with single old-school friction sway control.
05-24-2019, 05:28 PM
Hmmm. I don’t think so but we’re heading out tonight so I’ll pay more attention to where the sound is coming from. But does anyone know what I’m talking about with the wheels flexing or am I absolutely crazy? I’ll take a picture when we pull out tonight.
2016 F150 4x4 Sport
05-24-2019, 05:29 PM
Two thoughts when I read your post.
First, you said you had your bearings packed. I'd have them checked. Wouldn't be the first time the mechanic left the bearings too loose. If he didn't follow the proper procedure the bearings could be quite loose which could account for the popping noise. If you have leaf springs supporting the axle the shackles (the link on one end that lets the spring get longer or shorter as it's deflected) and bushings (on both ends, both shackle and fixed ends), can be the source of popping noises too in tight turns.
If no obvious mechanical source the "leaning" could well be an optical illusion. When a travel trailer with tandem axles is in a tight turn the tires are under immense side forces. The treads will be forced either in or out (in relation to the center of the trailer) until they actually skid sideways on the pavement. When you look in your mirror and see the upper sidewall in line with the wheel and the lower sidewall at an extreme angle your mind logically jumps to the conclusion that the wheel itself is "leaning". It might lean some if there is any flex in the spindle end of the axle but usually not enough to actually cause a mechanical lean in the amount you are seeing.
Again, perhaps an illusion due to what I explained.
If you can, jack up the wheels and check for looseness by gripping at top and bottom of tire and see if it can be wiggled. Can also check at 3 and 9 for good measure. Shouldn't be more than the slightest feel of looseness. If the wheel moves enough to see the movement, not just feel it, have a mechanic check. Perhaps not the same one as last time
05-24-2019, 05:45 PM
Tandem axles are going to flex on turning. Avoid overloading and very sharp turns as that could lead to frame or hanger damage.
05-24-2019, 05:49 PM
TitanMike, since you’re in the PNW you probably know Les Schwab Tire Centers. Good reputation and I trust them. That’s who packed the bearings.
The tire lean is definitely NOT an optical illusion. I’ll post a pic but it might be after the long weekend.
Thanks for your thoughts.
2016 F150 4x4 Sport
05-24-2019, 05:52 PM
So, should they “pop”? Like I said, even going around a normal size cul-de-sac they pop every few feet or so.
2016 F150 4x4 Sport
05-24-2019, 07:00 PM
As I mentioned earlier, you need to determine if it is definitely the wheel hubs popping or if you're hearing the sway control in the wdh. Have someone drive slowly and turn while you walk beside the tt.
05-24-2019, 10:29 PM
Retired Old Fart
Yes, are you disconnecting the anti-sway bar from the WDH in a tight turn (like a cul-de-sac)? They can not only make popping noises, but can be damaged if the turn is too tight.
I would also jack up the trailer and check the tires/hubs for wiggle and even rotation. If it's loose, you need to pull and inspect why. It's not impossible a bearing has started to fail. Hell you could have packed a China bearing yesterday and have it fail tomorrow. It's not unheard of them to be bad right from the factory in the first trip. Not super common, but not unheard of either.
05-24-2019, 11:57 PM
That is only a problem with the add-on friction bars, not the WDH with integrated anti-sway. The OP hasn't mentioned which WDH they have, just wanted to clarify that such turns are not a problem with all WDH w/ anti-sway.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
05-25-2019, 12:00 AM
No, there should be no popping noise from your axles or hubs. I would jack up one side of the trailer to lift the tires off the ground (jack using the frame, not the axle tube) and check for bearing play by hand. It won't take much force to make them wobble by hand if they're loose, just grab the tires at the 9 and 3 position and push/pull, then do the same at the 12 and 6 positions. If the bearings are loose you'll know it, there should be little to no play when you do that so if you get noticeable movement then whoever packed your bearings didn't do the job correctly.
2013 Shamrock 21SS
05-25-2019, 12:58 PM
I don't believe that "pop" you're hearing is the hubs. It is the trailer suspension, i.e. springs, hangers and equalizers. On the sharp turn in a cul-de-sac there is a lot of stress on those parts. On a tandem axle trailer the tires will cant because of the angle you're pulling them. If all is well they should straighten out and track correctly within 10 feet in a straight pull.
2016 Salem 27RKSS
05-25-2019, 01:24 PM
We have axles, I forget what they are called, that are not hung from shackles. They have an encapsulated rubber piece that provides the suspension. I investigated this before but that was a couple of days ago, lol. No popping sound but the tire did flex to a crazy angle. Google it, that's what I did. Found a place in Lubbock Texas that makes axles, both kinds.
05-25-2019, 01:46 PM
Cheap check.... get some 1/2 decent spray lube...not wd40 but thin. Spray springs and shackles.
You can jack it up and spread open the spring ends and put a bit of grease in there if this helps/fixes it.
This is void if you have torsion axles
Edit: someone mention the suspension
2017 Puma 297RLSS
05-25-2019, 03:12 PM
I assume you have checked the torque on the wheel nuts, loose wheels can give a popping sound on turns.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
05-26-2019, 05:41 AM
Now are you sure what your calling wheel flex is really not the tires that will flex on a tight turn?
