Old 02-05-2012, 03:54 PM   #11
Dallas Texas
TexasBBQ's Avatar
Lou - As you said there was a metal tag on each axle with the info. What is SLR?
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 02-05-2012, 06:17 PM   #12
sherdep's Avatar
my guess is single load rating
I tried to do a search on that but didnt find anything referencing what SLR stood for
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 02-05-2012, 08:50 PM   #13
Herk7769's Avatar
My guess is "Shock Load Rating" but a call to their tech suppport should answer it. Post here if you do contact them.
HAM CALLSIGN - KC3FFW
Old 02-05-2012, 09:25 PM   #14
sherdep's Avatar
after looking at what you posted Lou - I would have to bet you are right on the money with Shock Load Rating -
Old 02-06-2012, 11:19 AM   #15
I was told by a tech at the dealer this weekend to only put 2-3 pumps into the bearing annually as the seal is pretty easy to overfill and blow out.
2012 Shockwave 23FSMX
2010 Dodge 3500, SRW, G56, full deletes
2000 Yamaha V-Star 1100 Classic
BioMan is offline   Reply With Quote
Old 02-06-2012, 11:52 AM   #16
acadianbob's Avatar
Interesting. I occasionally pump until I see the new grease coming out so that I know all of the old grease has been replaced.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 02-06-2012, 11:54 AM   #17
MtnGuy's Avatar
Same here. Wipe out excess grease, pump, wipe out black grease, continue that process until it turns red....or whatever color the new grease is.
Old 02-06-2012, 12:44 PM   #18
Just passing along what I was told. I've always done the pump-till-clean method mentioned above as well.
Old 02-06-2012, 12:47 PM   #19
MtnGuy's Avatar
It is good information, BioMan. I will do further research before doing my bearings this spring.
Thanks for posting.
Old 02-06-2012, 01:24 PM   #20
Wanna Be Camper
SaskCampers's Avatar
I pump ours out till I see clean grease as well. I do this very slllllooooly as well.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
axle
