Old 05-28-2013, 04:06 PM   #1
Steve Jackson
sideout1961's Avatar
Ez-lube Axles
Well greased the axles for the first time today. All went as advertised new grease in old grease came out. As Herk had warned in another thread watch out for the zerk fittings. Two of mine were just laying inside when I took the rubber seal out. One question I have though is what's the easiest way to get the grease gun off the zerk fitting. I don't know if it's because I have a new gun but I had a heck of a time pulling it off the fitting.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 05-28-2013, 04:26 PM   #2
wyo700's Avatar
Usually by just tilting the grease gun one way or the other it comes off. At least mine does. Trying to pull straight doesn't work so well.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 05-28-2013, 04:35 PM   #3
Steve Jackson
You got that right! It definitely won't come off pulling straight out.
Old 05-28-2013, 04:54 PM   #4
MC9
Quite often the end has an adjustment.
MC9 is offline   Reply With Quote
Old 05-28-2013, 05:01 PM   #5
Steve Jackson
Just watched a video and the mechanic said to just tilt it at an angle and twist and it worked every time he did it. I'll have tomtrynit next time.
Old 05-28-2013, 07:28 PM   #6
semi-senior member
denandra2's Avatar
What type and brand grease did you use for your axles?
Dennis & RuthAnn
Tippy too!
Columbus (2014)320RS
2014 Ram 3500 DRW 6.7HO
Aisin 6speed Auto
SE Mo
denandra2 is offline   Reply With Quote
Old 05-28-2013, 07:42 PM   #7
Steve Jackson
http://www.harborfreight.com/grease-...rip-66664.html
Old 05-29-2013, 05:52 PM   #8
Originally Posted by sideout1961 View Post
denandra2 asked what brand grease did ya use ...
melk-man is offline   Reply With Quote
Old 05-29-2013, 06:19 PM   #9
jevanb's Avatar
I grease mine with mobile 5 which is what we use in our acft wheel bearings, if it is good for them It ought to hold up to my demands. because I dont sit in -40 for hrs then heat up to 300plus in seconds
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 05-29-2013, 06:38 PM   #10
Dexter has a list of approved greases. I suspect that isn't on it!
