Old 03-11-2015, 10:05 AM   #11
vinmaker's Avatar
I have yet to do this myself. A bit scary.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 03-11-2015, 10:23 AM   #12
Originally Posted by gljurczyk View Post
your the only person who can find USA seals, even Napa say's that all bearings and seals are now made over sea's. It not the seals it how you put in the grease. Pretty easy to tell if you blew your seal. And yes I know that your new bearings say USA on them. You can buy USA made bearings on ebay. But who knows how many sets that guy bought when they were still made here. Maybe Napa was wrong with the info they gave me. I agree with flybob.
Don't know how you can tell if you have a blown/defective seal until your brakes go bad. Maybe Napa doesn't stock US made seals?
Old 03-11-2015, 11:06 AM   #13
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by litgrep View Post
I had no problem. First time through it will take about a tube of greese an axle. Use a manual gun, not a pneumatic.
And that's my objection to the EZ Lube setup. Not the cost but the result - a hub full of grease.
FWIW, I'm an ASA certified Master Mechanic and have taught brakes and front end at a local tech school before retiring. Just using common sense will make it obvious to anyone that the only grease that is "working" is the grease packed within the bearing rollers and races. A little extra grease should be placed on the inside edges of the inner and outer bearings to be picked up as needed while the trailer is rolling down the road. The inside of the hub should remain grease free to allow for expansion and heat dissipation. That's the way they came from Dexter, isn't it? That's why it takes a tube per axle. You're filling up the hub Dexter left empty, as they should.
I wonder how many users of the EZ Lube axles who thought they had forced grease past their seals were actually victims of heat expanding the grease with no place for it to go.
Just my 2 cents.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 03-11-2015, 11:17 AM   #14
If the grease expanse it will come out the front of the hub the same as it does when you put grease in the zerk.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 03-11-2015, 11:18 AM   #15
KMP44's Avatar
I was asking a few questions about the E-Z Lube axles last time I had our Roo at the dealer. The mechanic there told me their recommendation to everybody who had E-Z Lube hubs was to not use the grease fittings. This surprised me, but the reason was that they get a lot of seal failures in for repair after owners have greased them which is an expensive job. Its not everyone that has an issue, but they see enough of them that they recommend just treating them like traditional bearings. Inspect annually, re-pack as needed. It also eliminates the issues of incompatible grease being added and the mess of completely filling the hub.
Something to consider, I guess. But it certainly surprised me when the tech's opinion was that the E-Z lube's create enough issues that worth considering not using the grease fittings.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 03-11-2015, 11:18 AM   #16
AKA: 'tiredTeacher
awellis3's Avatar
You run with the grease cap off?
Wright and Penny
Richmond, Va.
Old 03-11-2015, 11:27 AM   #17
There is a rubber plug in the end , no grease cap on the ez-lube like I had on my non ex-lube axle.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Old 03-11-2015, 01:05 PM   #18
I agree with awillis3 You should never pack the bearing Assembly full of grease. I have run into many failed bearings over the past many year due to too much grease. It traps the heat in the bearing as it is an insulator and will not let the heat transfer to the wheel hub. This will overheat the bearing and will cause the bearing to fail.
hope this helps Tim
TimVWulp is offline   Reply With Quote
Old 03-11-2015, 03:24 PM   #19
Greased my bearings last summer on my unit. Went on line and found several real good videos on how to do it. Replaced old grease with a different cooler grease so I could tell when most of it was out. As I greased each wheel I spun the tire. Had a container along with a stick to get rid of the old grease. Took some time but felt it went real well.
Bears1985 is offline   Reply With Quote
Old 03-11-2015, 03:30 PM   #20
Well, when I get the rest of my new Timken bearings and SKF seals, I will repack them and fill the cavities with Lucas Red "N" Tacky via the grease fitting on the end of the axle like I have for the last 9 years. Haven't had a problem yet, but who knows???
Got the 4 outer brgs today. Guess where they were made?
Name:	Timken outer bearing.jpg
