Old 12-05-2015, 01:10 PM   #31
Witch Doctor's Avatar
I just got a F-250 2007 with 33,000 miles on it. I changed the tires to Michelins MS/2 17". the truck had the original tires on it. I don't know why ford puts those Pirelli tire on them. I know they give you a softer ride but terrible for towing. My wife even complained about how the truck floated without the 5er attached. The tires were 9 years old, so really it was a dry rot problem. I have about 200 miles on the new tires and it has taken the play out. I swear by Michelins, have used them on all my trucks and cars.
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-05-2015, 07:21 PM   #32
Just replaced Michelin P rated tires with Michelin LT tires on my 2012 F150. Haven't towed with them yet, but they do ride a little rougher unloaded but not that much. They are inflated to 45psi front and rear. May experiment with 40psi. Will start with 60psi when I tow. Tried to get a load/inflation table from Michelin, but no luck with that.
Two things to keep in mind, the load rating on your P tires is reduced to 91% when used on trucks. Also, check your wheel psi rating to see if it will safely handle the full psi rating of the LT tire. Unfortunately, I could not find this information for my Ford factory wheels.
Baldicon is offline   Reply With Quote
Old 12-07-2015, 07:27 AM   #33
MilCop4523's Avatar
3 dealers recommended that the LT's run 50 lbs in them unless towing.
the lower pressure apparently in their experiences have lead to premature tire tread wear.
so we run ours at 50 unless hauling the 5th wheel.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 12-07-2015, 07:33 AM   #34
MilCop4523's Avatar
hope this helps
image taken from second link
http://www.trucktires.com/bridgeston...loadtables.pdf
http://www.rvtirepressure.com/assets..._inflation.pdf
and
Old 12-07-2015, 11:35 AM   #35
MilCop, I found the inflation table you linked, unfortunately I have 18' wheels which are not included in the table. The 45psi unloaded was recommended by Michelin when I contacted them about an inflation table.
Old 12-07-2015, 02:17 PM   #36
Steeljag's Avatar
Anyone running / towing with the new Mich LTX M/S Defender tire on a F150 or similar 1/2 ton? This is what I'm focused in on for the summer, and I am concerned about ride quality.
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 12-07-2015, 02:31 PM   #37
Pickin' & Campin'
See my post # 29 in this same thread.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 12-07-2015, 02:59 PM   #38
Steeljag, just put a set on my 2012. Haven't towed with them yet. At 45psi unloaded (recommended by Michelin), the ride is a little harsher, but definitely not a show-stopper.
Old 12-07-2015, 04:11 PM   #39
Steeljag's Avatar
Thank you Picker and Baldicon !
1930 lbs CCC
Old 02-09-2016, 05:28 PM   #40
Mark S's Avatar
I just today installed a set of Michelin Defender LTX 275-65 / 18 tires on my F150. I was also concerned about the ride quality. I was pleasantly surprised with the ride quality. The truck feels more solid and cornering is much better with less lean. It has only been a day but so far I think I may like the ride better now.
I am looking forward to towing with these new LT tires. My tires only had 12,000 miles on them but I did not like the "mushiness" of the stock P rated Goodyears when towing. I sold my old tires for $300 so it worked well for me.
Mark and Joanne
2014 Fun Finder XT 276
2015 Ford F150 Lariat 3.5 Ecoboost 4X4 SCrew Max Tow
2011 Harley Road Glide Ultra
Mark S is offline   Reply With Quote
f150, tire, tires
