Old 07-06-2015, 09:06 PM   #11
I agree B&B I will video on our trip to the Dealer.
DJalbertacanada is offline   Reply With Quote
Old 07-06-2015, 09:17 PM   #12
Originally Posted by DJalbertacanada View Post
...Old Coot the cabinet skin returns to normal when trailer is supported by the landing gear
Could still be what I said. Any movement could cause it. If you pull the trim on any cabinet you will see most are a very loose fit.
Old 07-06-2015, 09:48 PM   #13
lckeehne's Avatar
I have a crack in fiber glass exterior it runs from the corner of the slide out in bedroom towards the front. Right now it is 5.25" long.
I think it is from the flexing of the nose of fifth wheel.
lckeehne is offline   Reply With Quote
Old 07-06-2015, 10:47 PM   #14
I will check this out, I have to admit I thought that the tolerance may have been too tight to begin with but after seeing the panel return to normal as the landing gear takes the weight off of the hitch it makes me very suspicious.
No doubt if I trimmed the cabinet piece down it would not flex but I still feel that the bowing of the cabinet side is due to flexing of the front frame. Hard ot see in the poor quality vid I uploaded but the small passenger night side table also moves independent of the side wall. Something is causing the floor to flex upward.
Old 07-06-2015, 10:49 PM   #15
What make/model/year is your rig?
Does the crack expand as you put weight on the pinbox (retract the landing gear?)
Can you video inside the bedroom as you travel?
Old 07-07-2015, 06:38 PM   #16
VinceU's Avatar
Problem is your rig is suspect, warranty or not it needs to be inspected by someone who is aware of the possible failure. Not all structure failures follow the same rules. Inspection will conclude if the flexing is acceptable or a failure has started. Your call of course.
VinceU is online now   Reply With Quote
Old 07-07-2015, 09:13 PM   #17
If your pinbox has moved upward at the pin, then you may have a bad weld(s) at the pin beam. Found this on my 2008 Montana 2955 in the middle of the Yukon on return from Alaska. Added pictures to show how bad it can be. Keystone folks did NOTHING for me!! Fortunately limped in to Whitehorse with 1" clearance between truck bed and 5th wheel. Spent a week and about $5k in whitehorse replacing beams and having front cap rebuilt.
ID:	82329   Click image for larger version
ID:	82330   Click image for larger version
RubberNail is offline   Reply With Quote
Old 07-07-2015, 10:59 PM   #18
2007 WildCat 32QBBS
05CrewDually's Avatar
You need to pull down the fascia around the pinbox and fully inspect the frame cross members. The metal is too thin of a wall thickness and ends up shearing. It happen to my Wildcat and many other fivers. I was lucky to make it home and ended up repairing it myself because Lippert kept making excuses and was NO help. They acted like it was normal for an over the road coach to do that. Here's mine.
Best of luck.
05CrewDually is offline   Reply With Quote
Old 07-07-2015, 11:28 PM   #19
I got a response from Forest river this AM, the Service spokesman has stated that some movement is normal, I then sent him a link to the video, I am interested to see what he says.
Thanks everyone for pics etc.
I am wondering Rubbernail and Crewdually if you saw any signs (hindsight being 20/20) of excessive movement in the front of your coach prior to this failure.
Old 07-08-2015, 12:23 AM   #20
2007 WildCat 32QBBS
I started noticing it a year in advance. The fiberglass front would bow out a little. Then it started shearing screws that hold up the fascia. Finally it got to a point where I could see the coach flex closer to the truck's bed rails on every bump while traveling.
I sent them a video and everything. The final immature email I received from a different LCI representative blamed me, saying I added the hitch on the back and that caused the front frame to crack. The hitch was from the factory and even had their sticker on it. They totally jerked me around for weeks until I finally bought 16 feet of 6x2x.25" tubing and repaired it myself. Personally I believe it came out better than what they would ever build anyways. I also added an air hitch.
Looking back I should of called my insurance company and put in a claim. It's about a $5,000 job but I did it myself for a few hundred or so even with the shiny diamond plate.
fifth wheel, frame, wheel
