Old 07-09-2016, 07:13 AM   #1
Rhody's Avatar
Firestone Tires
Anyone running Firestone Destination AT's 16's
Was wondering about towing tire pressure for these tires.
Says max tire pressure 44 psi.
Anyone run max in rear or should pressure be the same all the way around?
Thanks in advance!
Rhody
Rhody is offline   Reply With Quote
Old 07-09-2016, 07:37 PM   #2
Airdale's Avatar
Are you talking about tires for your truck? Normally tires with a 44# max PSI rating are passenger tires.
A Trailer Tire Poster
Airdale is offline   Reply With Quote
Old 07-09-2016, 07:43 PM   #3
Rhody's Avatar
Hi thanks for the reply.
No these are All Terrain tires for my Tacoma 4x4
I pull a 25ft TT
Old 07-09-2016, 08:22 PM   #4
HONDAMAN174's Avatar
I would run the maxim the rear when towing. If you have a sway problem you may have to upgrade to LT tires.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 07-09-2016, 08:25 PM   #5
Is your tire size P265/70/16? That's a passenger tire.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is offline   Reply With Quote
Old 07-10-2016, 02:11 PM   #6
Airdale's Avatar
The maximum load capacity displayed on your passenger tires is for use on passenger vehicles, mainly cars. When used on a pick-up truck that value must be de-rated. That is done by dividing the displayed load capacity by 1.1. You also need to do that when lowering the inflation pressures.
The recommended tire inflation pressures were set by the vehicle manufacturer when the tires were fitted to the vehicle. So they were set using the de-rated values for the inflation pressures recommended for the fitment.
tires
