Old 10-08-2016, 11:13 PM   #1
First blown tire.
My day had finally came today. I blew the right front tire on our Surveyor. Our tires are the OEM tires, Towmax STR power king. Our TT is three years old and we agreed we would replace them next year. Well this morning on I-75 S just after we left Cordele, GA. Tire pressure was checked yesterday prior to heading out. Cruise control was set at 65, in the right hand lane. We heard a pop and I felt the TT "wiggle" a bit. DW asked what was that, I told her we blew a tire. I was off the road and parked in short order. We don't have TPMS, but have been thinking about installing a system. Not sure if it would have helped today. I use a laser thermometer and check tire temps at each stop.
ID:	122462   Click image for larger version
ID:	122463   Click image for larger version
ID:	122464   Click image for larger version
2017 Keystone Cougar 28RDB
Buck1032 is offline   Reply With Quote
Old 10-08-2016, 11:43 PM   #2
Phenom's Avatar
Any damage to the trailer or just a blown tire? Sounds like you handled it well.
Sean
'16 28DBUD
'16 2500HD Dmax
Phenom is offline   Reply With Quote
Old 10-08-2016, 11:45 PM   #3
NMWildcat's Avatar
I think you were very lucky getting 3 years out of those blowmax tires AND you seem to have had minimal damage. Congrats!! It is sad when the life expectancy of ST tires is 2 years. So what new tires are you looking at?
Scott and Liz - Southern NM
Old 10-09-2016, 12:22 AM   #4
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
I'm absolutely amazed that your Towmax tires lasted that long. I blew all 4 of mine the first year in less than 2,000 miles. Those tires are just enough to get the TT off the lot and not much more.
Please make sure you record all the info on the sidewall and report it to NHTSA so something can be done about it. If people don't report the blowouts, we will still see this garbage coming out of the factories. Take lots of pictures of all the numbers on the edge of the sidewall so you can send them to NHTSA.
You need to give some serious thought to replacing all the other tires ASAP.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 10-09-2016, 12:32 AM   #5
Zero damage to the trailer, sorry I should have gotten that in there first. We have had some issues of throwing money out the window this year which trumped replacing the tires this year. So we are getting tire put on here in Tampa at a Goodyear shop. That one will be the spare till we get home. Then I will research tires and replace all tires at home.
Old 10-09-2016, 12:38 AM   #6
Give Maxxis M8008 a look. Great tires IMHO.
Old 10-09-2016, 12:41 AM   #7
Iwannacamp's Avatar
Pretend I am a see'er. Ha ha
I am thinking cord separation or impact damage.
Will see what someone who actually knows says.
Our new 5er 10-26-16
Days camped 2016 8
Old 10-09-2016, 12:41 AM   #8
NMWildcat's Avatar
I hope it is not far to home. In my experience, one flat has always turned into two (tire on the same side). Don't know whether the first flat damaged the other tire or the stress of all the weight being on the remaining tire caused the failure. It has happened that way to us 3 times over the years. Each time it was always at least 100 miles to the next town where we could buy tires, and we just didn't make it. Hope you have better luck!
Old 10-09-2016, 12:49 AM   #9
NMWildcat's Avatar
X2!! And LT tires are even better
Old 10-09-2016, 12:50 AM   #10
That is my fear as we will not leave here without a new spare. From Tampa we head to Ft Wilderness for family fun. I am going to read, research, poll everyone, Google and pray when the search for new tires are going to happen the week we get home.
tire
